T273 Filter cross references?
/ T273 Filter cross references? #1
Mike5252
Cleveland, Ohio
JD 2320
Has anyone been able to track down Wix or Napa cross references for any of the T273 filters?
/ T273 Filter cross references? #2
I've been wondering this myself. Now this is untested but here is what I came up with.
The orginal TYM part # for the engine oil filter is 31A40-02100
According to this post, that part number crosses to this: MD134953
On the wix website, MD134953 crosses to this. a 51365
I have another 40 hours to go before my next service, but I will follow up if that is the right one or not.
Roady
/ T273 Filter cross references? #3
I've found the WIX part #'s for fuel and oil, I'll post both with NAPA x-ref when I get home. What about the hydraulic filters? There are 2 on the 273??
/ T273 Filter cross references? #4
273 has only one HST filter.
Roady
/ T273 Filter cross references? #5
Hello all. Does anyone have a part number for the HST filter on the T273 ?
Thanx.
/ T273 Filter cross references? #6
Thanx.
13152302100
/ T273 Filter cross references? #8
I have a T233 tractor. Not sure if all the filters are the same but here are the Wix Numbers
Oil wix#51365
Fuel wix# 33262
Hydraulic wix# 51586
Air outer wix# 46438
Air inner wix# 42985
/ T273 Filter cross references? #9
Oil wix#51365
Fuel wix# 33262
This is very helpful! Thanks for posting this. :)
/ T273 Filter cross references? #10
Two different engines iirc . so do these even cross reference for T273's?
/ T273 Filter cross references? #12
Oil wix#51365
Fuel wix# 33262
I am trying to do the oil and hydraulic filter change on my Montana T2334. As far as I have been able to tell it is the same as the T233, but when I tried the WIX number above for the hydraulic filter it does not look the same. The thread seems the same but the seal is completely different. the filter I took off has a seal that is 3x thicker and higher then the one I picked up.
Can anyone help with this? The WIX site doesn't have the Mitsubishi S3L listed. What am I missing
/ T273 Filter cross references? #13
So I have tracked down the filter numbers sold by the dealer and they match what I bought. The NAPA dealer could only guess that the filter was changed since I bought the tractor.
So I need to either wait to hear from someone here or just try to use it. I really don't like the idea of putting it on and pouring in the fluid only to have it leak the first time I start it up. Such a big difference in gasket size is making me nervous.
If there is anyone that has changed these, please let me know what you found.
/ T273 Filter cross references? #14
Neuropel said:
I just checked the WIX site and the 31A40-02100 cross references to a WIX 51358 filter. I have been unable to find a cross reference for the HST filter 13152302100
Sorry for responding in such an old thread. I did some digging and found that the Wix 51356 is identical to the 51365, and 51358, but it has a 3.4" long body, rather than 2.6" or 2.8". If you have the clearance, it means more filter media to trap particles before the by-pass valve would open. I had to slide the fuel line over a little, but I had room when I changed my oil this weekend. 50hrs and going strong so far.
I did use a Fram filter (even they are usually not my first choice), the PH7317, which crosses with the 51356, and is also the same filter I run in my car. Maybe I can by them in bulk now.
/ T273 Filter cross references? #15
engine oil filter for cub cadet ex2900 with a yanmar diesel need part number and manufacture source.
/ T273 Filter cross references? #16
Been a long time for this thread.
I used the filters listed above and there have been no issues. The thinner gasket has worked well. No leaking and no engine issues.
/ T273 Filter cross references? #17
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
KMC 3386 (A64119)
KMC 3386 (A64119)
John Deere 561M Baler (A63111)
John Deere 561M...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2023 BOBCAT T66 R-SERIES SKID STEER (A64279)
2023 BOBCAT T66...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
