T273 Filter cross references?
/ T273 Filter cross references? #1
Mike5252
Cleveland, Ohio
JD 2320
Has anyone been able to track down Wix or Napa cross references for any of the T273 filters?
/ T273 Filter cross references? #2
I've been wondering this myself. Now this is untested but here is what I came up with.
The orginal TYM part # for the engine oil filter is 31A40-02100
According to this post, that part number crosses to this: MD134953
On the wix website, MD134953 crosses to this. a 51365
I have another 40 hours to go before my next service, but I will follow up if that is the right one or not.
Roady
/ T273 Filter cross references? #3
I've found the WIX part #'s for fuel and oil, I'll post both with NAPA x-ref when I get home. What about the hydraulic filters? There are 2 on the 273??
/ T273 Filter cross references? #4
273 has only one HST filter.
Roady
/ T273 Filter cross references? #5
Hello all. Does anyone have a part number for the HST filter on the T273 ?
Thanx.
/ T273 Filter cross references? #6
Thanx.
13152302100
/ T273 Filter cross references? #8
I have a T233 tractor. Not sure if all the filters are the same but here are the Wix Numbers
Oil wix#51365
Fuel wix# 33262
Hydraulic wix# 51586
Air outer wix# 46438
Air inner wix# 42985
/ T273 Filter cross references? #9
Oil wix#51365
Fuel wix# 33262
This is very helpful! Thanks for posting this. :)
/ T273 Filter cross references? #10
Two different engines iirc . so do these even cross reference for T273's?
/ T273 Filter cross references? #12
Oil wix#51365
Fuel wix# 33262
I am trying to do the oil and hydraulic filter change on my Montana T2334. As far as I have been able to tell it is the same as the T233, but when I tried the WIX number above for the hydraulic filter it does not look the same. The thread seems the same but the seal is completely different. the filter I took off has a seal that is 3x thicker and higher then the one I picked up.
Can anyone help with this? The WIX site doesn't have the Mitsubishi S3L listed. What am I missing
/ T273 Filter cross references? #13
So I have tracked down the filter numbers sold by the dealer and they match what I bought. The NAPA dealer could only guess that the filter was changed since I bought the tractor.
So I need to either wait to hear from someone here or just try to use it. I really don't like the idea of putting it on and pouring in the fluid only to have it leak the first time I start it up. Such a big difference in gasket size is making me nervous.
If there is anyone that has changed these, please let me know what you found.
/ T273 Filter cross references? #14
Neuropel said:
I just checked the WIX site and the 31A40-02100 cross references to a WIX 51358 filter. I have been unable to find a cross reference for the HST filter 13152302100
Sorry for responding in such an old thread. I did some digging and found that the Wix 51356 is identical to the 51365, and 51358, but it has a 3.4" long body, rather than 2.6" or 2.8". If you have the clearance, it means more filter media to trap particles before the by-pass valve would open. I had to slide the fuel line over a little, but I had room when I changed my oil this weekend. 50hrs and going strong so far.
I did use a Fram filter (even they are usually not my first choice), the PH7317, which crosses with the 51356, and is also the same filter I run in my car. Maybe I can by them in bulk now.
/ T273 Filter cross references? #15
engine oil filter for cub cadet ex2900 with a yanmar diesel need part number and manufacture source.
/ T273 Filter cross references? #16
Been a long time for this thread.
I used the filters listed above and there have been no issues. The thinner gasket has worked well. No leaking and no engine issues.
/ T273 Filter cross references? #17
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Case CX350 C (A65053)
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
