T233, Tire pressure?
/ T233, Tire pressure? #1
jigs_n_fixtures
Veteran Member
Salmon, Idaho
TYM T293 CAB, & T233
I went through the manual, and can’t find any information on tire pressure.
I have the standard R4 tires.
What is it supposed to be?
/ T233, Tire pressure? #2
I don't have a TYM, but for that machine I would imagine that 15-20 psi would be reasonable front and rear. If you have a loader you should run the fronts at the max psi printed on the tire.
/ T233, Tire pressure? #3
Look at the maximum tire pressures on the sidewall front and rear. I don't have a Tym but on similar size tractors I'll run ten to fifteen pounds of pressure in the rear tires and around thirty in the front.
