T&T - Which T more useful?
   / T&T - Which T more useful? #51
</font><font color="blue" class="small">( Jeff, when your cutting dirt or have a PHD, the tilt cylinder is nothing short of delightful. The top link however should be just as much a part of the tractor as all five wheels, it's that important to me. )</font>
What function does the tilt do on a post hole digger? Not disagreeing, just not seeing what use there is for tilt?
--->Paul
   / T&T - Which T more useful? #52
--->Paul
   / T&T - Which T more useful? #53
While stumblin' around in a tractor graveyard I came across a pile of links. one was in decent shape and evidently came off a Ford 8N. At least my Dad's had one just like it. It had a rod, threaded on both ends with a sleeve on the bottom, and a crank and gear on the top. Rotating the crank handle shortens or lengthens the rod. This isn't an adequate description. I'll try and remember to take a pic. /forums/images/graemlins/wink.gif
   / T&T - Which T more useful? #54
   / T&T - Which T more useful? #55
The crank adjustable link arm you are talking about was pretty much standard on the N series Fords. It was really nice to be able to reach back from the seat and adjust the tilt of the rear blade. My DX29 and several other new tractors have them, and you can find them as aftermarket items, too. Unfortunately, the seating position on the DX is so high I have to get off the tractor to turn the crank. /forums/images/graemlins/smirk.gif Still, it's way better than the turnbuckle, wrench, or ratchet lever adjustment found on a lot of CUTs.
   / T&T - Which T more useful? #56
   / T&T - Which T more useful? #57
I do have an HTL. It is on most of the time. It only comes off if I need the 3rd SCV for something else (grapple e.g.).
To the others that detailed the worm gear side link: Thanks - I'll start surfing for details on where to buy one.
   / T&T - Which T more useful? #58
   / T&T - Which T more useful? #59
Now I need some information. I have one set of hydraulics on the rear of my machine and would like to have T&T. Is there a economical way to do this. The worm gear for tilt could be it but hydraulics are my friend!! Second question is what tilt cylinder should I buy? And lastly do I need a check valve on it?
   / T&T - Which T more useful? #60
2020 DRAGON ESP...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
