system 7010
/ system 7010 #1
landlord
simplicity landlord system 7010
Anybody know how the traction control works on the old 70's landlords? the manual says it has it but I don't think it's working right still doing one wheel wonders :-(
/ system 7010 #2
It has a spring loaded limited slip differential in the right rear axle.
/ system 7010
Right it powers both wheels until you turn but how does it disengage when turning
/ system 7010 #4
It compresses the springs when under force, allowing the differenential gears to disengage. You can put a washer under each spring to shim them, increasing the amount of force required before the gears disengage.
Or, you can replace the springs with new ones. Over time, these springs weaken...
/ system 7010
That's awesome I took it all apart and cleaned the 20 year old grease out and put new in that got it working better but I will defiantly try the washers thanks for the tip
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
HAY KING PASTURE AERATOR (A64278)
HAY KING PASTURE...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
Toro Workman Utility Cart (A64553)
Toro Workman...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
