system 7010
/ system 7010 #1
landlord
simplicity landlord system 7010
Anybody know how the traction control works on the old 70's landlords? the manual says it has it but I don't think it's working right still doing one wheel wonders :-(
/ system 7010 #2
It has a spring loaded limited slip differential in the right rear axle.
/ system 7010
Right it powers both wheels until you turn but how does it disengage when turning
/ system 7010 #4
It compresses the springs when under force, allowing the differenential gears to disengage. You can put a washer under each spring to shim them, increasing the amount of force required before the gears disengage.
Or, you can replace the springs with new ones. Over time, these springs weaken...
/ system 7010
That's awesome I took it all apart and cleaned the 20 year old grease out and put new in that got it working better but I will defiantly try the washers thanks for the tip
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2006 CHEVROLET TRAILBLAZER (A65054)
2006 CHEVROLET...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2017 Ford Expedition SUV (A64557)
2017 Ford...
