system 7010
/ system 7010 #1
landlord
simplicity landlord system 7010
Anybody know how the traction control works on the old 70's landlords? the manual says it has it but I don't think it's working right still doing one wheel wonders :-(
/ system 7010 #2
It has a spring loaded limited slip differential in the right rear axle.
/ system 7010
Right it powers both wheels until you turn but how does it disengage when turning
/ system 7010 #4
It compresses the springs when under force, allowing the differenential gears to disengage. You can put a washer under each spring to shim them, increasing the amount of force required before the gears disengage.
Or, you can replace the springs with new ones. Over time, these springs weaken...
/ system 7010
That's awesome I took it all apart and cleaned the 20 year old grease out and put new in that got it working better but I will defiantly try the washers thanks for the tip
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2013 Ford F-150 Crew Cab Pickup Truck (A64556)
2013 Ford F-150...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
