system 7010
   / system 7010 #1
landlord
simplicity landlord system 7010
Anybody know how the traction control works on the old 70's landlords? the manual says it has it but I don't think it's working right still doing one wheel wonders :-(
   / system 7010 #2
It has a spring loaded limited slip differential in the right rear axle.
   / system 7010
Right it powers both wheels until you turn but how does it disengage when turning
   / system 7010 #4
It compresses the springs when under force, allowing the differenential gears to disengage. You can put a washer under each spring to shim them, increasing the amount of force required before the gears disengage.
Or, you can replace the springs with new ones. Over time, these springs weaken...
   / system 7010
That's awesome I took it all apart and cleaned the 20 year old grease out and put new in that got it working better but I will defiantly try the washers thanks for the tip
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
