Synthetic Hydraulic Fluid & FEL performance
   / Synthetic Hydraulic Fluid & FEL performance #11
<font color="blue"> How or why is Amsoil Synthetic better than NH F200?</font>
It's not just a thinner oil, as previous posts about F200 indicate. It's a full synthetic that flows at -40F.
<font color="blue">Is it suitable for year roud use? </font>
Yep.
   / Synthetic Hydraulic Fluid & FEL performance #12
Check out Chevron All-Weather THF. Its a full synthetic rated for your machine. And like the Amsoil it does not improve cold flow by lowering the viscosity of the fluid. Just a fluid with a great natural viscosity index.
   / Synthetic Hydraulic Fluid & FEL performance #13
<font color="blue"> Check out Chevron All-Weather THF.</font>
I've already switched to Amsoil. /forums/images/graemlins/smile.gif
<font color="blue">And like the Amsoil it does not improve cold flow by lowering the viscosity of the fluid. </font>
Did you mean 'And like the Amsoil it does improve cold flow...'
   / Synthetic Hydraulic Fluid & FEL performance #15
Mike: Which Amsoil product did you use? I went to their website and found several versions. Is one more correct than the others?
   / Synthetic Hydraulic Fluid & FEL performance #16
<font color="blue"> Which Amsoil product did you use? </font>
Synthetic Tractor Hydraulic/Transmission Fluid, C-3, C-4.
There are 5 different ways to order this, from 1 quart bottles to a 55 gallon drum, but it's the only Amsoil hydraulic fluid I am aware of.
<font color="blue"> I went to their website and found several versions. </font>
What other products did you see?
   / Synthetic Hydraulic Fluid & FEL performance #17
Hydraulic oils available from Amsoil:
Synthetic Tractor Hydraulic/Transmission Fluid (ISO46, SAE30) ATH Available in qts, pails, drums
Synthetic Hydraulic Oil (ISO15) AWF Available in pails and drums
Synthetic Hydraulic Oil (ISO22) AWG Available in pails and drums
Synthetic Hydraulic Oil (ISO32) AWH Available in pails and drums
Synthetic Hydraulic Oil (ISO46) AWI Available in pails and drums
Synthetic Hydraulic Oil (ISO68) AWJ Available in pails and drums
Synthetic Hydraulic Oil (ISO100) AWK Available in pails and drums
Contact me and I can give you more info: dave@ultimateoiltechnology.com
Dave
   / Synthetic Hydraulic Fluid & FEL performance #18
<font color="blue"> Hydraulic oils available from Amsoil: </font>
The context of this discussion is tractor hydraulics therefore the only Amsoil product that applies is ATH-Synthetic Tractor Hydraulic/Transmission Fluid, ISO 46, SAE 30
None of the other ones you mentioned apply.
<font color="blue"> Contact me and I can give you more info: dave@ultimateoiltechnology.com </font>
TBN offers very reasonable advertising rates for your oil business. /forums/images/graemlins/smirk.gif
   / Synthetic Hydraulic Fluid & FEL performance #19
<font color="blue">
</font> The question was whether there was one Amsoil hydraulic oil or several. There are several, but you are correct, only one applies.
<font color="blue">
TBN offers very reasonable advertising rates for your oil business. /forums/images/graemlins/smirk.gif </font>
These forums are a great source for ideas and information. Thanks for the info /forums/images/graemlins/smirk.gif
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
Makita Impact Drill with Charger (A57454)
Makita Impact...
Steel Square Fuel Tank (A57454)
Steel Square Fuel...
