Synchronized Shifting - Idling
/ Synchronized Shifting - Idling #1
Rvrrat14
Texas
Yanmar YM347A Bush Whacker HD72 shredder, Armstrong BGR64-5 grapple, E.L. Caldwell 66” box blade, Advanced Earth 48” pallet forks, 43x45 Safety Basket
I have a question concerning idling a Yanmar YM 347 with the synchro shift in Neutral and the Main and Range still in gear. Is it best to put ALL levers in N and Paring Brake ON when idling. My thought is that the transmission still in gear with the Synchro Shift in N still allows the main transmission to spin. Your thoughts.
/ Synchronized Shifting - Idling #2
The shuttle shift (forward/reverse) is the first section in the transmission, then comes the main gears (1st to 4th) and finally the ranges (High - Med- Low).
So when you put the shuttle lever in Neutral, nothing else spins in the transmission. Well, other than the PTO drive train but that goes through different shafts.
Leaving the shuttle lever engage in either position, but main gears in Neutral, means the entire shuttle shift drive train is spinning.
On my tractor, while it's not an Yanmar, it still uses the same 12x12 transmission. I just leave the shuttle lever in neutral.
I was told by Yanmar that if the main and range levers are not in N and the reverse lever/synchro is in N, the gears continue to turn.
/ Synchronized Shifting - Idling #4
If that's indeed the case, I would need a parts or preferably a service manual to study and learn about that transmission arrangement. Do you happen to have one? I've only found parts catalogue for the YT models and none of those are shuttle shift transmissions.
I know that pretty much all of the Korean manufacturers and several others, have the transmission arranged as such: Shuttle shift as first section, then main gears as second section and finally the range gears as the last section. If the shuttle lever is in Neutral, nothing beyond that will spin.
/ Synchronized Shifting - Idling #5
The transmission shaft is the outer shaft and first goes through the synchro reverser, then the main shift, then the range shift shaft. If the reverser is in neutral, the outer shaft will not turn and only the inner shat will turn. The inner shaft is what goes to the PTO clutch to operate the PTO. Only the reverser lever is associated with the neutral switch which is located on the left side of your tractor under the floorboard.
Upon further considerations, I, too believe the Reverser in Neutral does in fact stop actions through the transmission. If the trans is in gear, as well as the range, and the Reverser is in N, and the tractor tires do not turn, well……..
/ Synchronized Shifting - Idling #7
Consult the operator's manual, if you have it. If the lever positions are important for neutral, the manual "should" give instructions. For example, there are certain models of Caterpillar where the gear levers need to be in a certain position for stationary PTO work, or, on some, the PTO work needs to be periodically paused and gears selected in order to provide splash lubrication to the through shaft and bearings.
/ Synchronized Shifting - Idling #8
I don't know if I understand what's going on, but I think you are right.
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59914)
2019 CHEVROLET...
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A59914)
2019 FREIGHTLINER...
John Deere 6000-Series Tractor Lift Arms (A65640)
John Deere...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Camco Running Gear (A66408)
Camco Running Gear...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
