Synchro Shuttle on '05 1533
   / Synchro Shuttle on '05 1533 #11
Shop says they need to replace gears...what would cause this? Sounds a bit fishy to me
I have seen trans that 1 gear failed and took out the whole trans. Large chunk of gear broke off and damaged all the other gears.
From the sounds of your issue I would say that is possible. If it was acting up before the grinding I would say possibly a bent shift fork or synchronizer, but without seeing the thing I am just guessing. Too many things that could go wrong, a bearing failure that allowed a shaft to move so things weren't meshing correctly, etc.
Hopefully the mechanic can tell what cause the failure so it won't happen again. Just from the few people I know with similar tractors it is rare for the MF trans on a compact to fail.
It turned out to be better than expected. I'm not exactly sure what broke as my dad picked tractor up Saturday, but it was a bunch of sheared bolts holding the pinion (?) or planetary drive part stable. Pops is no mechanic and him trying to relay what mechanic said is a bit difficult. Mechanic did say that it may have been due to the amount of loader work we had been doing going back and forth and jolting drivetrain. I'm thinking bolts worked loose over time and compounded the issue. Just thankful the repair was only $450 and not the $2900 it could have been.
   / Synchro Shuttle on '05 1533 #13
Glad it turned out better than expected. Nothing is cheap to repair anymore.
Thanks...and you are correct on nothing being cheap anymore. Hoping to use the savings to help clear the last few acres we had timbered 2 years back.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2017 CATERPILLAR 420F2 IT BACKHOE (A60429)
2017 CATERPILLAR...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Deere 333E (A60462)
Deere 333E (A60462)
