Synchro Shuttle on '05 1533
   / Synchro Shuttle on '05 1533 #1
schoolsout
Awendaw, SC
Massey Ferguson 1533
OK, I think I have this figured out, but want to make sure. Just bought an '05 MF 1533 with 8x8 Synchro Shuttle and from what I've read, I will need to press clutch pedal down to shift into forward or reverse, right?
Also, once in forward or reverse, I need to press clutch in fast, change gears and then let clutch out in a slower, smooth manner, correct?
Any other tips I should know/be aware of dealing with this transmission?
Thanks!
   / Synchro Shuttle on '05 1533 #2
Used to drive gear tractos 30 something yearss ago ,hydro lately.You got the synchro shifting right, forward and reverse without coming to a full stop useing the clutch.
Changing gears and ranges useing the clutch but at a full stop.
Thanks
wondering if we made a mistake by not looking for tractor with hydro (as of now, I have no really open areas to just cruise and will probably be doing a lot of F and R), but this is my first one so other than the hydrostat mower we have, I won't know the difference (I guess)
   / Synchro Shuttle on '05 1533 #4
the price you paid there is no mistake . with hydro n gear each are best suited for certain types of work. have a 1428v hrdo getting a 1533 SS . i m glad i can keep the hydro after i get the SS . each will be used for the type for work that they are best suited for.you can always get a hydro if you find another great deal, and have 2 tractors.
Thanks
Last thing we need now are two tractors...
We woke up that morning not really serious (like 100% on buying), but saw the ad and bought it. Should finally get some seat time tonight.
   / Synchro Shuttle on '05 1533 #6
I have synchro shuttle in my 1532 , I really like it . The book says to use clutch , and I do , but MF has a video comparing MF , New Holland and Kubota showing not using clutch shifting f & r . This transmission and clutch requires very little effort to engage / disengage .
   / Synchro Shuttle on '05 1533 #7
The PowerShuttle is the one where you don't need to clutch when going forward to reverse and back.
I've definitely got it down now. Heading up to the property tomorrow to see what I can make happen...
helped spread 12 yards of topsoil for my sister on it today
Had an issue last weekend with this tractor. Everything was find for a while and then when put into reverse, it is like the gears in trans or differential or whatever weren't meshing correctly and it would make a loud grinding noise while going nowhere. This only happened in reverse so didn't do that again. Used tractor to put one more tree in ground and it started happening in the higher gears going forward...same thing. Gears weren't meshing together and just made a grinding noise (putting into gear is fine...it just does it when clutch is let out). Started to just use 1st low and it seemed ok as we were loading up. Messed around and put into 4wd and it seemed that it wouldn't make noise as front axle was pulling as well so rear didn't have a chance to make the noise. Put the tractor up and plan to take it to shop as soon as we can. Even in 4wd, when turning sharp, you could feel the rear kind of lugging from time to time.
Any idea what this could be?
Shop says they need to replace gears...what would cause this? Sounds a bit fishy to me
   / Synchro Shuttle on '05 1533 #11
I have seen trans that 1 gear failed and took out the whole trans. Large chunk of gear broke off and damaged all the other gears.
From the sounds of your issue I would say that is possible. If it was acting up before the grinding I would say possibly a bent shift fork or synchronizer, but without seeing the thing I am just guessing. Too many things that could go wrong, a bearing failure that allowed a shaft to move so things weren't meshing correctly, etc.
Hopefully the mechanic can tell what cause the failure so it won't happen again. Just from the few people I know with similar tractors it is rare for the MF trans on a compact to fail.
It turned out to be better than expected. I'm not exactly sure what broke as my dad picked tractor up Saturday, but it was a bunch of sheared bolts holding the pinion (?) or planetary drive part stable. Pops is no mechanic and him trying to relay what mechanic said is a bit difficult. Mechanic did say that it may have been due to the amount of loader work we had been doing going back and forth and jolting drivetrain. I'm thinking bolts worked loose over time and compounded the issue. Just thankful the repair was only $450 and not the $2900 it could have been.
   / Synchro Shuttle on '05 1533 #13
Glad it turned out better than expected. Nothing is cheap to repair anymore.
Thanks...and you are correct on nothing being cheap anymore. Hoping to use the savings to help clear the last few acres we had timbered 2 years back.
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
WATER TRAILER (A58214)
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
