Switching hydraulic valve functions on my telehandler
/ Switching hydraulic valve functions on my telehandler #1
BeezFun
IL
Kubota B2710
This thread is a continuation of this previous thread about switching the tilt and telescope functions on my telehandler. Here is the portion of the hydraulic diagram showing the valve bank labeled D, and the electro controllers labeled BP. The two valves of interest are the tilt valve labeled EI and the telescope valve labeled ET:
A more detailed look at the valve bank:
Here is the wiring to each of the valve controllers, the grey wire is from the ECU and is listed as sending 0-12v. The blue wire is ground:
What I'm thinking in the above diagram is swapping connectors X395 and X391 with connectors X393 and X397. I have more detailed diagrams of the internals of the valves if that helps.
tnx
/ Switching hydraulic valve functions on my telehandler #2
Do all of the pilot valves have same part number in the parts breakdown? If yes then should work to swap those connections.
If the PB pilot block is remote like schematic shows could also potentially swap the pilot lines but this would be messier than swapping wires.
I'm not sure I understand enough to know all the right names for things, and it doesn't help that they use five different names for the same thing and the manual is in five different languages. But here is the parts manual page that shows what they call the electro controller and the valve bank.
Item 1 is the thing they have been calling the electro controller, now they call it the hydraulic block. Item 2 is the solenoid, there are 8 of them in the electro controller, and they all have the same part#. The valve bank is in the lower left corner of the page, it doesn't have an item number because it is called out in detail in a separate parts page, and each of the valves in that bank have a separate part#.
So my Fred Flinstone level understanding of how this works is that each of the 8 wires from the ECU goes to each of these solenoids, applies a voltage from 0-12v, and that controls the pilot flow to the four valves in the valve bank. Is that correct?
/ Switching hydraulic valve functions on my telehandler #4
Item 2 does appear to be the pilot valves and if they are all the same part number they should then have the same voltage- milliamp command signal and should provide similar pressure output based on command signal.
Long way of saying I believe you can swap the wires and they should work. If picture is accurate they should have plugin style connection on each valve so may be able to simply swap the plugs vs trying to find pin out and swap wires at some connection point.
Thats my Barney Rubble thoughts anyway.
Thanks, I'll have to pull some covers and look at that controller. I'm hoping that harness has enough slack to let me swap those connectors.
Say hi to Betty and Bamm-Bamm
/ Switching hydraulic valve functions on my telehandler #6
Is the pilot valve manifold buried so that you can maybe see it or touch it, but not both at the same time.
I can almost picture you beating on the covers of that machine yelling Wilma!!😁
I'm not sure how buried it is, I can't see it by peeking into all the visible places. The manual has a diagram that shows its location near the ECU, which is fairly easy to access. I can see the valve bank so I might be able to follow the lines back to the pilot.
I have a wireless endoscope that attaches to my phone, the thing works great and can snake into almost any area. So probably after the weather turns lousy and my outdoor honey do list is expired, I'll pull the machine into the shop and spend some time on it.
/ Switching hydraulic valve functions on my telehandler #8
This information probably isn’t helpful except maybe for preventing a problem.
I have been in business of heavy equipment repair since 1967. Back in 2007 I was helping a friend who owned a 2006 Cat tele-handler. Problem was the rocker switch that controlled the fork tilt was faulty and after tilting down it would keep going when you let off unless you tilted back momentarily to stop it. They didn’t sell any parts for the joystick. So he ordered a joystick ($1k) and I went to put it on but the plug was different. I called Cat parts and they looked it up again and with a number from the joystick on the machine they found the correct one which was a later type. He said we can order that one but there is a notation that the ECU must be programmed to learn the new replacement. So be careful with your plans. Personally I think it’s best to learn the standard system than trying to make it learn you. Although I have made four stick backhoes into two stick backhoes when it was just linkage.
Thanks, I decided to make the switch on the output side of the ECU where it connects to the valve solenoids. None of what I'm changing involves the CAN bus and I have the voltage specifications from the service manual which are supposed to be identical for the two solenoids. I'll check that with a multimeter before I make the switch, hopefully I won't let any of the smoke out.
/ Switching hydraulic valve functions on my telehandler #10
That’s a better place. There could be variations with the ECU output for the size of the hydraulic cylinders. Maybe you can adjust the amount to vary the control by hand. There could also be travel limits or other sensor information to the ECU.
Yes there is one sensing switch on the telescope and I can't figure out what it does. It's a NO/NC switch pair that changes state when the telescope extends, and the ECU monitors it. I'm guessing it's some part of the safety system. I'm going to ask the dealer if they can find out what it does.
UNUSED FUTURE EXCAVATOR THUMB MOUNTING PLATE SET (A60432)
UNUSED FUTURE...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
