Switching hydraulic lines
/ Switching hydraulic lines #1
I am in the process of installing a snow blade on the front of my Kubota L3000. It will be attached under the front and I will be removing the bucket. It is a blade off of a pickup. What I want to do is to switch/reroute the hydraulics from the bucket lines so I can use the joystick to raise and lower the blade and to turn it left and right. What I am looking for is a valve to shift the hydraulics from the bucket lines to the plow blade lines. It will need to switch 4 lines. I would like to do this with one valve/handle. Are they out there? I've seen them for 2 lines but not 4.
/ Switching hydraulic lines #2
/ Switching hydraulic lines #3
If you are removing the FEL, I don't understand why you would need 4 lines. The FEL lift line lifts the blade and the curl lines angle it.....
If you are only removing the bucket, then you need a 3rd valve to control the angle, or use the curl valve by fixing the curl in one spot with clamps of some type.(plow lift chain back to FEL structure) I like the 3rd valve system
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
