Sway chain help
   / Sway chain help #1
zack76401
JD 2555, MF 245
Hello,
Im active duty USAF in afghanistan and need some guidance. I have 2 JD2555 tractors here and 2 Brand new MX10 cutters. I was wondering if someone could tellme where to get some sway chains for the tractors and where/how to attach them to these tractors. I also have a MF 245 tractor with chains already attached . We were considering fabbing some chains up, but not sure on how to attach them and make them adustable.
Any help/info appreciated.
Zack
I apologize if this is the wrong forum and moderators please move it to correct forum if its wrong please.
   / Sway chain help #2
NO apologies neccessary Zachary,
Your in the right place.
You would be money and aggravation a head by goin to the quartermaster
and seeing if they have some 3/8" turnbuckles that are 12 inches long and welding a drilled weldment to the left and right lower links and drilling a hole in the hitch at the appropriate point for the inside turnbuckle.
The drilled weldment would be the size of the turnbuckles pins ONLY and be the about one inch by one inch and it will be welded on both sides-unless you have some thick angle iron that can be cut on a power hack saw or a hand hack saw- if done by hand be sure to use a pair of small pieces of metal to guide the blade when cutting by hand as you will get tired and it will want to wander a bit if it is thinner than the thickness of the space within the turnbuckles ears.
If turnbuckles are unavailable, you can use chain heavy work or tow chain and a pair of 1/2 inch shackles for the frame attachmernt point and drill in to the lower link arms at a one or two points on the lower link arms to give you some adjustment. to attach the ears of the shackles
You will most likely need one inch shackles to pass over the lower links and 1-1/4" link chain to attach it to the hitch which will be the easiest point to avoid contact with the P.T.O. shaft.
I am very surprized that this John Deere Mule from Europe does not have sway chains or points to attach them.
Short of that you could order the turnbuckles from Mcmastercarr and have them at the APO, AFPO, in KABUL or Ramstein from thier warehouse in New Jersey or Europe.
Using turnbuckles gives your more physical control of the implement and it amplifys the control of the lower link on either side, please keep in mind the you may need larger turnbuckes- the ears of the turnbuckles will nee to be wide enough for them to pass over the drawe bar and to secure them with the turnbuckles pins-sizing the weldments for the opposit turn buckles still applies- saying that a properly welded shackle on each lower link will work well-you just need to secure the turn buckle to the drawbar first.
NO-THERE IS NO USING A SMOKE WRENCH ON EITHER THE DRAW BAR OR LOWER LINKS!
I will gladly help you with this repair if you do not have a large motor pool shop in your area as it will be easy to do and manage.
go to bed and get some rest, god bless you and your crew.
Asaalam Alaaikum.
   / Sway chain help #3
I can't provide any useful information. But, I want to thank you for your service.
What you do, allows us to enjoy the toys on these forums.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
