Swapping a 4WD front axle?
/ Swapping a 4WD front axle? #1
electrycmonk
Near Denton, TX
Satoh 370(still in storage mode); Cub Cadet 7260 (overheated & awaitint time for repairs); 7360SS Cub Cadet, 7300 Cub Cadet; L2250 Kubota that needs a shifter forlk replaced
I’ll findout Saturday when I go see it & hopefully buy it.
My 1998(?) 7260 standard 4WD is in a coma currently (thread in here already) and I was thinking about swapping that front axle under a 2003 7360.
The 7360’s front axle is advertised as needing front wheel seal replaced.
I figured back both up and swap the axle … at least temporarily until I can track down the axle seal and stuff to repair it.
Meanwhile I was definitely going to swap wheels so that the correct ratio is maintained with tire/wheel combos.
Then when it warms up I can order the parts for repairing the 7260 in the spring. Repair the 7260’s overheating issue & maybe even the clutch job too?
Butidigress.
/ Swapping a 4WD front axle? #2
When changing the front axle from one type of tractor to another, it is more important to consider the gear ratio than the tire diameter. Since both axles are from tractors of the same manufacturer with little difference in year of manufacture, chances are they will have the same gear ratios.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
