SVL75-2 error code 008
/ SVL75-2 error code 008 #1
Walter63
My SVL75-2 track steer has been sitting unused indoors for a couple months in an unheated building . It started up just fine yesterday, but gave an error code 008, which the manual says has to do with the no reading from the water in fuel sensor.
Seems like the problem has something to do with sitting in the cold.
Does anyone have experience with this error code ? Should I run it for a few hours and see if anything thaws out ?
/ SVL75-2 error code 008 #2
Maybe a rodent ate the wire during the prolonged storage.
If related to possible water in the fuel, I'd at least drain/inspect the filter to make certain all clear before using.
Added in edit:
This was listed in the SL95-2 manual:
E: 008 Fuel sensor system - - -
Machine Performance: The fuel level indicator does not appear on the meter. The machine's other functions are still operative.
Provisional measures and correction: Immediately contact your local dealer
Report back on the corrective action taken.
Link to reference text: https://kubota.ca/getmedia/70f24742-e906-44ad-96f0-ee15a5dc08d6/OPS-SVL95-2-V0631-58113-ENG-20160711?ext=.pdf
Thanks. The warning light and code went away on its own. I'm thinking that some water may have frozen in the separator and that effected the sensor.
All's well that ends well....
/ SVL75-2 error code 008 #4
Your manual says it’s a water sensor code? My SVL75-2 says the same thing as moship’s 95 manual - code 008 is no reading from fuel level sensor. E9120 is water separator. My book has no code that there is no signal from the water separator but it does have E008 for no signal from the fuel level sensor.
JIB Wheel Loader Forks (A62177)
JIB Wheel Loader...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A61567)
2025 JMR Single...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63118)
Hobart Champion 16...
John Deere TX Gator (A60462)
John Deere TX...
