Suspenders...
/ Suspenders... #12
I use them to keep my bed sheets on and in place.
/ Suspenders... #14
I'm not aware of this style, do you have a link to one?
Yes they are the Holdups linked to in post #2,
some of my jeans are over a year old with no damage from the suspenders,
which are worn daily I wear jeans everywhere but, weddings, and funerals
/ Suspenders... #15
/ Suspenders... #16
I skipped over suspenders and went straight to overalls. Big Smith.
/ Suspenders... #20
I have used holdups and suspender store for a long time. I wear them over my t-shirt which is then under my button down. I don't wear outer type T shirts because I need pockets.
Anything with clips will eventually destroy your pants. The metal does scratch things and if you sweat a lot they will rust all the metal parts. They will also pinch you if you're not careful.
The plastic clips are good but still will get too loose to hold your pants up. They use a cam type clamp that is all plastic so it wears then has no grip.
I have moved to the type where you buy a pack of denim buttons and press them through your pants like crimps and the leather straps have slits in them that go on the buttons. They are just like the main button on your jeans and haven't come apart.
The only issue is they have dyed leather and the dye will bleed onto your shirt if it gets wet. But they haven't let my pants down once as opposed to both the metal pin clips and the plastic grip clips have.
It's a weird feeling when you feel one pop loose and you have to go make an adjustment.
I haven't found perfect ones yet. 41yiXbY4FaL._AC_SY400_.jpgScreenshot_20200827-021014_Opera.jpg
2009 Bobcat 430 (A60462)
2009 Bobcat 430...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
2 Row Planter (A60463)
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Toro Sand Pro (A56859)
