"Survey of Repairs on Your Tractor"
   / "Survey of Repairs on Your Tractor" #31
Re: \"Survey of Repairs on Your Tractor\"
'95 Kubota B7100. 650 hours - other than typical tightening of loose stuff and a new battery, haven't had to put a wrench to it. Do keep the oil and fluids changed/topped off and grease well regularly.
Bob Pence
   / "Survey of Repairs on Your Tractor" #32
Have owned 4 Kubotas since 1994,5th one on the way.Several hundred hours combined.Had the same noise in front drive-line area that's been mentioned on the B2710.Dealer promptly repaired,under warranty.Taking BX in Monday to have the "sticking Hydro pedal" replaced,again warranty issue.Even if these repairs were made out of warranty,they would be an inexpensive fix.
   / "Survey of Repairs on Your Tractor" #33
L3600 with 200 hours
1) Tightened FEL hose - leaking at the fitting
2) Water in the FEL control cable froze the joystick below 32 deg. Had to remove the assembly, and free up with WD40.
3) Replaced the radio.
   / "Survey of Repairs on Your Tractor" #34
Re: "Survey of Repairs on Your Tractor"
1999 Cub Cadet 7260 with 285 hours. Only problem so far has been a blown hydraulic hose on my 418 backhoe after about 100 hours on the hoe. Dealer warranteed the part.
I noticed today that my front tires, Titan R4s, are severly weather cracked and allowing the liquid ballast in them to seep out. I was real surprised to find that as my tractor has never spent any time outside except when it was actually being used. I'll have to speak to my dealer about that....
   / "Survey of Repairs on Your Tractor" #35
JD 4400 :
1. Day 2 had oil leak from under seat. Dealer came to house and removed seat and tightned screw.And put in order to replace blinker light switch.
2. At 175 hours:
A. Differental lock failure.
B. Nut come loose on brake.
C. Tractor hard to start(replaced fuel pump)
D.Starter not engaging all of the time replaced starter.
E. Also had developed a different oil leak on rear end.
F.Replaced hydro tranny because of metal shavings from differental lock failure.
3.At 260 hours:
A. At times tractor still hard to start,have to play around with fuel pump,tap on it lightly etc to get it to start.
B.Small leak,just enough to notice a light wet area where tractor had been taken apart for hydro work,not enough to effect the level,may stop as time goes buy,watching it though.Still have about 10 months on warranty,I will wait and see if anything else goes wrong before I have them correct,fuel pump and oil leak.
   / "Survey of Repairs on Your Tractor" #36
2001 B7500st at 20hrs had small front wheel seal leak. Dealer fixed no questions
   / "Survey of Repairs on Your Tractor" #37
Jan 2001 Kubota BX2200 with 75 hrs.
Fuel tank replaced due to leak.
Fuel sender seal replaced as not put on properly after tank replacement.
One FEL hydraulic line.
All warranty and great service.
Three point top link would not turn. Dealer and 4' breaker bar fix, on my dime.
   / "Survey of Repairs on Your Tractor" #38
'99 b2710, 140hrs
rear tire valve leaked when delivered. dealer came out and fixed it.
Differential lock got stuck once, had to step on it a few times to unstick it. Dealer greased something at the 100 hr maintenance.
FEL stick rattles, haven't done anything about it. Front lever to lock the MMM on also rattles, again, too lazy to do anything about it.
Many small dings in paint to left of seat from letting the seatbelt snap back while it's retracting. Oops.
Everything else I've ever thought was wrong was just my not knowing how to adjust something or such.
Todd
   / "Survey of Repairs on Your Tractor" #39
<font color=blue>Many small dings in paint to left of seat from letting the seatbelt snap back while it's retracting. Oops. </font color=blue>
Sorry, just had to laugh! Been there.......
   / "Survey of Repairs on Your Tractor" #40
1995 JD 955. Bought last Aug. with 426 hrs. Now has 485 hrs. & haven't had any problems. FEL & 72" mid mount mower.
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2020 DRAGON ESP...
2016 MACK PINNACLE (A58214)
2016 MACK PINNACLE...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
