"Survey of Repairs on Your Tractor"
   / "Survey of Repairs on Your Tractor" #11
Re: \"Survey of Repairs on Your Tractor\"
1999 B7300HST 235 Total hours (bought used from KUB dealer w 188 Hrs)
at 195 hours, found dealer had overtighened belt, causing belt to rub lower hose making a hole. Dealer claimed he couldn't fix for 2 weeks till part arrived (Belt and hose). Purchased new hose ($12) and new belt ($ 10) from another dealer same day. Installed myself.
At 210 hours, noticed small fuel wetting (seepage) under fuel delivery pump. Screws holding diaphram were not tight. Removed pump and tightened. Leak fixed.
Steve
   / "Survey of Repairs on Your Tractor" #12
B1750HSD 550 hours. Had to replace the front grill when a log rolled off the FEL and mangled it. No other repairs.
L3010 190 hours. No hits, no repairs. Flawless performance.
Pete
www.GatewayToVermont.com
   / "Survey of Repairs on Your Tractor" #13
Kubota B2710 bought new 3/01 and currently showing 71 hours. Left rear tire and rim replaced under warranty. Tire side wall lamination was defective from Goodyear. Rim had a slightly deformed edge. Probably not a problem but was easier for the dealer to deliver new tire on new rim to remedy the tire defect. Like GlueGuy, my FEL joy stick rattles when the FEL is not on. Haven't done anything about it yet.
Dave
   / "Survey of Repairs on Your Tractor" #14
TC29D
replaced hydraulic hose on loader
in the process of putting in a new battery
Ernie
   / "Survey of Repairs on Your Tractor" #15
CB-Doc
I’ve had two repairs on my New Holland TC45D. Both of them have been warranty work.
Purchased tractor in February, 2001.
35 hr: Deluxe FEL Joystick broken (metal shaft in center of joystick). Dealer replaced complete joystick with new unit.
75 hr: Found battery leak had deteriorated/corroded hydrostatic transmission cooling lines, radiator, and parts of the battery shelf. Evidence showed this had happened during transport to dealer or while on his lot. Dealer replaced all at no charge to my complete satisfaction.
Currently, I have 105 hr on my tractor.
JimI
   / "Survey of Repairs on Your Tractor" #16
Doc,
98 Kubota B21, 675 hrs, a couple of broken hoses on the backhoe (my fault) and a fuel tank cap that split (go figure).
MarkV
   / "Survey of Repairs on Your Tractor" #17
BX2200 26 Hours two leaking FEL Hoses.
Winnipeg, Manitoba
2001 BX2200 (26 hrs)
   / "Survey of Repairs on Your Tractor" #18
Re: "Survey of Repairs on Your Tractor"
B7500 HSD purchased new July 2000. 115 hours, no repairs.
Steve
   / "Survey of Repairs on Your Tractor" #19
1999 TC29D Now 250 hours
At 50 hours had to have the "tilt wheel" cylinder replaced on the steering column. Had a fogging dash until I was able to store it indoors (problem solved). Other than that, just normal maintainance.
   / "Survey of Repairs on Your Tractor" #20
Hew Holland TC25D. About a hundred hours and no problems of any kind. Its a great machine and I should have bought one years ago.
Giyi 72" Grapple (A57149)
Giyi 72" Grapple...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
Year: 2020 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 50,546 (A56859)
Year: 2020 Make...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2019 TAKEUCHI TL8 SKID STEER (A52709)
2019 TAKEUCHI TL8...
