Super UDT
/ Super UDT #21
Junk- you are correct, but the manual states either UDT or SDT can use used. Based on the manual either one can be used and be 100% fine.
Unless Kubota makes a Global statement you can use either and be fine.
I also think you are missing the point here. It is up to the customer to select either one. Also either one is not wrong. So if I select UDT I can put in UDT or Amsoil. If I want to put in Super Duper UDT, I can only install Kubota fluid and not Amsoil.
Either fluid, no one is wrong since it passed either UDT or Super UDT. Does not state it must pass Super only for hyd.
If anything, the manuals sucks on this issue.
/ Super UDT #22
</font><font color="blue" class="small">( .............If anything, the manuals sucks on this issue.
)</font>
The manual sucks on many issues. The problem is that Kubota Japan doesn't want to outsource the manual writing to the USA or other English speaking countries, so they try to do it with there Japanese to English translators and it doesn't work very well. This is one of the reasons that the quantities for engine oil are also wrong. Kubota leaves a lot to be desired in there manual writing capabilities to say the least. Junk....
/ Super UDT #23
"So if I want to fill my BX with UDT oil, I can use Amsoil or UDT fluid
Then on the other hand, if I wanted to fill my BX with SDT, I can’t use Amsoil fluid"
You can use 1/3 UDT 1/3 Amsoil and 1/3 Super UDT.
You can use 100% of any of the three or any of the two or any of the three in any percentage you want. The resulting mixture will influence the cold weather performance more then anything I suspect. As the Super UDT specification says, "Super UDT is fully interchangeable with standard hydraulic fluids." "For best results, we recommend that you not mix fluids"
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2014 DODGE 5500 SERVICE TRUCK (A65643)
2014 DODGE 5500...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Front Tank Bracket (A64126)
Front Tank Bracket...
