Super UDT vs Sae 80-90wt
/ Super UDT vs Sae 80-90wt #1
JBR
NE Pa
bx1500-M5700
I'm sure I read in my bx1500 manual, trans fluid "use super UDT or sae 80-90wt gear oil. I'm going to look again but that sounds NUTS. Has anyone else read something like this?
/ Super UDT vs Sae 80-90wt #2
The manual is talking about the front axle case (at least on the B7500). You can use either gear oil or super UDT. Most Kubota's have super UDT in front axle case because many dealers say that it is just easier. However after reading many discussions on TBN about this subject, I decided to switch to 80-90 weight gear oil at my 50 hour service.
/ Super UDT vs Sae 80-90wt #3
I haven't read that but I wouldn't put gear oil into a hydrostatic transmission, I don't think that the gearoil's viscosity is designed to be pumped or filtered, I just read my manual on Saturday and bought 3 Gallons of Super UDT for my 300 hour service on my BX2200, the only place I read to use gear oil was in the gear box of the mower deck and the front axle. I'm just going off of memory on what I read but the Super UDT was $13.75 per gallon and It takes 2.7 Gallons to refill the case after you clean the screen on the 2200. so for $42 bucks I would use the hydraulic oil..
I Would never use 80-90wt in a hydraluic system either. I will read the book again and see where it is stated. I remember the guy who droped the bx off, he said to use a good hy-trans in the front diff. I don't like that idea either.
/ Super UDT vs Sae 80-90wt #5
My BX1500 manual states that you may use gear lube in the front axle or super udt. They ship with super udt in the front and trans so why not just replace with proper Kubota fluids. I would not try to save twenty bucks for the maintenance of a $9000.00 tractor. Your dealer should should be able to explain the fluids required to keep your warranty valid.
/ Super UDT vs Sae 80-90wt #6
You must not have read the whole thing or missed something. It had to be refering to the front 4Wd axle. The use of gear oil or hydraulic fluid in the front axle is allowed. There is no difference in performance in using either. Gear oil will simply take longer to drain then hydraulic oil. Both are good lubricants. Some are under the impression that the front bevel gears would be better served by gear oil because of "extreme pressure" characteristics it has, but my understanding of this term is that these types of forces on gears are developed at high RPM's, something your front gear case will never see. I use UDT.
/ Super UDT vs Sae 80-90wt #7
</font><font color="blue" class="small">( Some are under the impression that the front bevel gears would be better served by gear oil because of "extreme pressure" characteristics it has)</font>
I'd have to agree although I'm unsure if any operational benefit exists
in practice. FWIW I have been told by a dealer, Kubota itself sells
Kubota branded 80w90 for exactly this purpose.
To add to the confusion there are those who claim the 80W-90W
gear oil called out in the Kubota service manuals is different from
the 80w90 gear oil sold domestically.
In any case the function of the front axle oil is lubrication. The main
purpose of oil contained in the transmission is power transmission.
/ Super UDT vs Sae 80-90wt #8
The main reason to use Super UDT in the front differential is only applicable in cold weather climates. Super UDT flows better under low temperature extremes, which gear lube doesn't. For the small amount of Super UDT, I would use it in the differential for this reason. The cost differential between the amount of Super UDT and the gear lube is less than a meal at McDonald's!!!!
/ Super UDT vs Sae 80-90wt #9
</font><font color="blue" class="small">( For the small amount of Super UDT, I would use it in the differential for this reason. The cost differential between the amount of Super UDT and the gear lube is less than a meal at McDonald's!!!! )</font>
Well stated. /forums/images/graemlins/grin.gif
I reread the manual and every one is correct. It only states 80-90 wt for the front diff. I still find it strange that you can use a 10-30 wt hy-trans(super UDT) in place of a 80-90wt gear oil and get the same protection for the bevel gears. /forums/images/graemlins/confused.gif
/ Super UDT vs Sae 80-90wt #11
nothing strange about this at all. The oil is in there for lubrication of the bearings only. There is so little pressure on the gears themselves, any lubricant will suffice. If this differential were turning the speed of a automobile differential, then the pressures on the gears would be tremendous by comparison, so it would require a different type of lubricant. Today, cars use highly specialized lubricants for each component and many of them cost more per unit than Super UDT.
/ Super UDT vs Sae 80-90wt #12
Many manual transmissions have also gotten away from the heavy old gear oil. Automatic transmissions which are still filled with gears use a similar oil to that of UDT. It does not suprise me that a light weight oil can be used for bevel gears in a very slow speed setup.
/ Super UDT vs Sae 80-90wt #13
When I changed the front axle fluids in my B2400, I used Mobil 1 synthetic gear oil. Mine has the Bi-speed turn option and the Mobil 1 states on the bottle that it is compatible with limited slip differentials. This is a concern as the Bi-speed uses a clutch pack for the overdrive.
/ Super UDT vs Sae 80-90wt #14
My dealer said to use 80-90 gear oil in the front 4wd differential. That is what they put in when they service tractors. They think it works better then UDT here in the Texas heat.
John Deere 485 Riding Mower (A66408)
John Deere 485...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
