Super tech Hydr fluid??
/ Super tech Hydr fluid?? #1
Fordcummins83
Albuquerque, Nm
Little bit of everything
I have a Clark Michigan 45c wheel loader, and I'm currently running super tech Hydr fluid but last winter we had 3 ft of snow and I need this thing to clear my roads, but my hydraulics wouldn't work.. Does anyone know if this is just cheap oil and freezes? What could I do to prevent it from freezing?
/ Super tech Hydr fluid?? #2
The ST oil is made by three different companies and delivered by proximity of the plants. Here are the companies
Warren Dist./WPP,Exxon/Mobil and Shell/Pennzoil/Quaker State
Warren dist is in Nebraska I think, shell is in Texas and I do not know where the Exxon plant is. From reading on the net formulations between the Brand name and ST is minimal. If the ST hydro oil meets the specs for your rig you should be OK. If it is freezing I would check for water in oil and learn how it got there. If it is cold enough the oil will get thick, but usually after a warm up it will get moving again.
I checked for water and there is none that I can tell.. We left it running all night last year and it still got too cold to where I couldn't move my hydraulics
/ Super tech Hydr fluid?? #4
Does everything work as it should in the warm weather?????
/ Super tech Hydr fluid?? #5
i've never had an issue with supertech or travveler ( warren products ).. there are some 303 pureflo and premium oils sold at TSC and the pureflow will setup thick like molassis.. whereas the premium won't.
check the viscosity for your oil...
soundguy
/ Super tech Hydr fluid?? #6
Hey Sound guy I just filled my tractor with the Warren 303 xtreme oil from tractor supply, is that stuff OK........
/ Super tech Hydr fluid?? #8
i'm not sure where you live. i believe the extreme is a little better than the pure flo.
/ Super tech Hydr fluid?? #9
Live in Upstate NY so temps can get down to below zero. Anytime it is that cold the salamander gets blown on the middle of the tractor which covers the oil pan and the Hydro sump for 10 to 15 minutes minimum to warm things up a bit. I guess we will see though.
/ Super tech Hydr fluid?? #10
magnetic block heater for the pan and sump and a trickle charger for the battery might not be bad.. top the bat off.. keeps it warm.. keep the oil a lil warmer.. etc.... i think I'd have a lower hose or freeze plug coolant heater too.. if I lived where temps dropped below 0
/ Super tech Hydr fluid?? #12
Thanks SG I do have a lower hose heater and at 0 it gets coolant temps in the 50's if on for a while. I also have a tender on the battery. I have been thinking of a magnetic heater or a heated dipstick. Sorry for the mini hijack Ford.
/ Super tech Hydr fluid?? #13
forget the dipstick heaters.. they are just a neat way to burn oil... not enough surface area.. the mag block heaters are good though..
213104 (A64276)
213104 (A64276)
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A61574)
2006 Freightliner...
