Super S Premium Hydraulic Tractor Fluid
   / Super S Premium Hydraulic Tractor Fluid #1
grm61
Platinum Member
Eastern Washington
2013 Kioti DK45SE HST Cab
   / Super S Premium Hydraulic Tractor Fluid #2
I have been using the generics since I owned tractors. I did service my RTV with Kubota oil since it only took 3 gallons. I have 10 gallons of Super S waiting for my next hydraulic service. I wont be buying the expensive Kubota or Amsoil for any future oil needs. It says it meets the specs for Super UDT and about 20 others including most of the major brands of tractors so why pay double or triple for the dealer fluid. My Kubota dealer's service manager said that any oil that meets the Kubota specs will perform satisfactorily and not cause any damage to the system. ONLY reason to use dealer oil might be for warranty and even then, I would think that they would fall under the same clause in our warranty laws that they couldn't deny a claim if you use a "or equal" oil. Auto dealers bit the bullet on this in the 60's or early 70's when a class action lawsuit was filed against them for insisting that warranty is void if you didn't use their dealership brand oils and if you notice, they only show SAE class of oils now and not Ford, GM, Honda etc branded oils.
   / Super S Premium Hydraulic Tractor Fluid #3
The Super S data sheet advised it is a SAE 30 fluid. The original spec oil that Kioti had was a 10w-30. I think you'd be fine except for very cold temps.
I didn't even think about the Hyd being a multi grade, your right it does state on the Super S sheet that it is a sae30.
I think I will take it back. We do get good and cold in the winter, I just bought 5-40 Rotella T6 for the motor today for just that reason, no sense putting strait 30 in the hyd.
Thanks for pointing that out.
Also just found this on the net if anyone interested http://www.kioti.com/dealerden/files/2012/09/Lubricants-Chart-2012-07-20.pdf
   / Super S Premium Hydraulic Tractor Fluid #5
   / Super S Premium Hydraulic Tractor Fluid #6
Thank you for the chart! Very cool.
   / Super S Premium Hydraulic Tractor Fluid #9
   / Super S Premium Hydraulic Tractor Fluid #10
Thanks. I don't understand why they would block that site.
I do. It was the Kioti Dealer Den which requires a Dealer Log in and pass word. Somebody left the door open.
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2003 Big Tex 10PI...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
