super c hydraulics
/ super c hydraulics #1
badguyii
cromwell, mn
farmall super c
my super c has a farmhand loader on it. it has never worked right. it was my grandfathers tractor and his brother said it did not work right when they bought it used. the hydraulic pressure is intermittent, sometimes it works flawlessly for a half hour and sometimes it works for a minute and then it doesn't. I have been thru the pump and filter. thinking the safety valve and or spring in the block, sound right?
thanks for any input
/ super c hydraulics #2
I used to own a C. The hydraulic unit never worked but had a separate pump with hard lines going to it. Could you unhook those pipes and connect your vales to it??
it's plumbed right, like I said, when it works it works.
/ super c hydraulics #4
My best thought would be that either your valve your cylinders but I'm no expert.
swapped the valve out with another, same thing. cylinders are bad but that is not the problem. I ordered a oring and gasket set for the touch control block, my guess is I will find something in there bad or broken.
/ super c hydraulics #6
Had a similar problem on my Massey. The diverter valve was worn. Does this tractor have one?
not sure, I will look in to that, thanks.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
Caterpillar 12/14/120 Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
