super c hydraulics
/ super c hydraulics #1
badguyii
cromwell, mn
farmall super c
my super c has a farmhand loader on it. it has never worked right. it was my grandfathers tractor and his brother said it did not work right when they bought it used. the hydraulic pressure is intermittent, sometimes it works flawlessly for a half hour and sometimes it works for a minute and then it doesn't. I have been thru the pump and filter. thinking the safety valve and or spring in the block, sound right?
thanks for any input
/ super c hydraulics #2
I used to own a C. The hydraulic unit never worked but had a separate pump with hard lines going to it. Could you unhook those pipes and connect your vales to it??
it's plumbed right, like I said, when it works it works.
/ super c hydraulics #4
My best thought would be that either your valve your cylinders but I'm no expert.
swapped the valve out with another, same thing. cylinders are bad but that is not the problem. I ordered a oring and gasket set for the touch control block, my guess is I will find something in there bad or broken.
/ super c hydraulics #6
Had a similar problem on my Massey. The diverter valve was worn. Does this tractor have one?
not sure, I will look in to that, thanks.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
