Sulky question
/ Sulky question #1
js5020
Platinum Member
NE PA
Kioti CX2510, Kubota BX23S, AC5020, JDx300R
Guys I have a steering sulky for the com 12, and my experience with it has been less than enjoyable, I have been using it with the 30" deck and have added up to 30 lbs of weight to the front of the deck and the darn thing still wants to bring the deck up under certain conditions, basically if I had a third hand the thing would be ok, kinda tough to steer, operate the f/r control, and keep it from folding in the middle all at the same time with just two. How about the non steering sulky, is it any better? Has anyone made/adapted a stand up type sulky? Thoughts, experiences?
/ Sulky question #2
I have a non steering sulky. I have tried to use it without success. If the ground was level it would work great. The only good use I have found for it, is for carrying me between fields. Then I unhook it and mow the fence line. I would like to try a stand up sulky, I think they would work very well.
Solo
/ Sulky question #3
You could try adding more weight to the deck or go slower or walk with it and don't ride. Both sulkys will be the same on uneven ground. A stand on one might be a better option. - Kris :)
/ Sulky question
Thanks for the responses guys, guess I'll keep walking.
/ Sulky question #5
Hi! I fix a subframe and a hitch at my Gravely diesel. Now I want a sulky. I make a pencil draw for ONE WHEEL SULKY. I want your advice. Thanks! Oldmech
/ Sulky question #6
Oldmech- Look good ! I can't wait to see pics of the velke when it's done. - Kris :)
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2023 New Holland T5 120 Tractor (A64047)
2023 New Holland...
2005 MACK CV713 MIXER TRUCK (A63569)
2005 MACK CV713...
John Deere 6105D Tractor (A64047)
John Deere 6105D...
15K TRIPLEX PUMP (NONE TITLED) (A63569)
15K TRIPLEX PUMP...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
