Suitcase weight: is this ok?
   / Suitcase weight: is this ok? #31
Go for it Six.
I've got a 3pt weight rack that I use to store my weights and can pick it up with the rear QH so use it for a ballast when doing FEL work. I'll hafta get a pic next time I'm at the farm.
Once I start the 3pt project I will start a new thread and link it here. I'll need more advice and suggestions. :thumbsup:
Go for it Six.
Yes please do!
   / Suitcase weight: is this ok? #35
We've always kept suitcase weights whenever we sold a tractor. Here's a bracket I had to fab up up for the front of a Ford.
1/2"x6" flat bar was used. The weights are 120 pounds each IIRC.
Terry
Is that bottom hole in your mounting bracket suppose to have a bolt in? Looks like you might have lost one.
   / Suitcase weight: is this ok? #36
No. I used salvaged parts. There were no holes in the tractor frame in that area. There are 4 bolts holding the bracket to the FRONT of the tractor frame behind the suitcase weights also.
   / Suitcase weight: is this ok? #37
I've lost track of the number of times I've built something from salvage parts that had an unused hole. Post a pic and someone asks why that hole is there or whatever. I then have to explain I'm cheap. I prefer to call it "repurposing". :)
   / Suitcase weight: is this ok? #38
I gave up on the "repurposing" explanation long ago.
My friends all KNOW I'm cheap. :D
   / Suitcase weight: is this ok? #39
I fill extra holes and grind flat. First, it's good welding practice plus I don't have to explain. They already know I'm a cheapskate.
   / Suitcase weight: is this ok? #40
That's definitely doing it the RIGHT way, sixdogs.
Since I can't get away with a "lightening holes" explanation for a weight ballast bracket I'll have to add LAZY to my résumé. :)
Terry
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
