Suggestions for a trailer I found
/ Suggestions for a trailer I found #21
Having fruit trees, I would modify those posts to hold tripod ladders and pole saws, and build a deck for miscellaneous.
A couple weeks ago when it was raining, I draged the trailer into my barn to start messing with it.
Inside the trailer are some metal screens I traded a guy some work for. I was gonna use them on a dozer, but that never happened, so I've been sitting on them for over a year now.
This is a project that only gets worked on when the weather keeps me in and I have nothing else to do. I'm not a big fan of welding or working with metal, but will do what I have to in order to keep busy.
I spent a few days, on and off, stipping it down to the frame.
Whoever built the thing knew what they were doing, but for some reason left the frame like this on both sides. There was a plate over the top that added some strength, but I hate to see gaps like this.
Thats better. /forums/images/graemlins/smile.gif
I picked this up at Home Depot for $27. I saw cheaper ones in catalogs for $20, but this is close enough.
In order for it to work with the fourwheelers, I needed it to be able to get as low as possible, so I cut off the mounting bracket and welded in back on six inches from the bottom.
No I can lower it way down, or even higher then it is now.
Here's one of those screens I have. They are very heavy duty and should make a good solid floor. I'm also using them for the walls. It's a bit tricky welding it on due to the wire in the screen wants to melt before it flows. I lowerd my power setting way down to finally get a decent weld.
Demensions of the screes are 4' by 5', which should make a decent sized trailer.
I cut two more screens in half for the sides. To strengthen them and protect myself and others from the sharp edges, I trimmed them with half inch black pipe. I used black because it was the cheapest at Lowes. I'm not worried about rust, it's already covered in rust. /forums/images/graemlins/grin.gif
I reatached the diamond plate to the front of the frame for more storage and re-used the hose brackets for extension cords or hoses. It will also provide support for the screen and keep buckets from sliding off the diamond plate.
/ Suggestions for a trailer I found #29
I agree. It's surprising that whoever built it left those gaps unless he just didn't have a welder at the time.
To make the trailer multi-functional, I wanted the sides to be removable. I went with inch and a quarter pipe for brackets with one inch pipe sliding into it. That gives me a nice fit.
The screen likes to bow, so I used three vise grips, two clamps and two "U" bolts to hold it all together. I was beginning to run out of tools!!! /forums/images/graemlins/mad.gif
The top is half inch pipe, the post is one inch. I'm lining up the top with the screen, which brings me way off center from the post. This leaves a huge hole which I need to fill in.
A 5/16 bolt fit in there pretty good.
Then I welded it all up. This shows the weld still covered in slag. I'll grind it pretty later on.
I was planning on only welding about every fourth or fifth wire on the screen, but once I got started, I just did them all.
/ Suggestions for a trailer I found #35
</font><font color="blue" class="small">( To make the trailer multi-functional, I wanted the sides to be removable. I went with inch and a quarter pipe for brackets with one inch pipe sliding into it. That gives me a nice fit.
)</font>
Eddie -
That's a great idea! I have an old trailer (attachment) that I put a new wood deck on - I made all the sides out of 1/2 plywood - left / right sides are fixed - front and back are removable.
I also made the sides stackable / in two parts - so I can have "low sides" for easy shovelling of dirt etc - and "high sides" for hauling wood / leaves / debris etc.
There's rectangular slots in the the frame - so I cut 3/4" pine just wide enough to fit the slots - and this hold the vertical uprights of the sides - but I was never satisfied with the strength / stability - especially if I'm filling a load of cordwood.
Now I'm I think I'm going to get me some pipe & redo all the sides. I will try to keep the "multi-level concept" & have two sets of "stacking" sides / ends for different heights...I'll probably keep the wood siding though - just bolt through the pipe.
Thanks for the great ideas! /forums/images/graemlins/laugh.gif I just love TBN!
Dan
/ Suggestions for a trailer I found #36
Dan, how about 1.25 for the bottom with 1in fitting in it for the low section and 3/4ths sliding all the wat through for the top??
Hmmmmmmm. /forums/images/graemlins/grin.gif
/ Suggestions for a trailer I found #37
</font><font color="blue" class="small">( Dan, how about 1.25 for the bottom with 1in fitting in it for the low section and 3/4ths sliding all the wat through for the top??
Hmmmmmmm. /forums/images/graemlins/grin.gif )</font>
Varmintmist -
Even better! I'll keep that in mind! Thanks!
Dan
I had some time to experiment with morter on my entrance sign the other day and decided to give my trailer a try.
I took off the sides and loaded on several sacks of morter. The yellow buckets are full of water. The tools are lying loose on the floor.
The 1 1/4 inch pipe that holds on the sides also holds on my cement mixer. I forsee projects that I will want the mixer and my generator at.
Here's a closer look at the mixer. It slides over a one and a quarter sized pipe on the stand it came with, so I just did the same thing on the back.
I have two places it could go. Left or Right.
I was a little worried about the weight on the back with a full load, but it was unfounded. No tipping issues at all.
