Jeff59Va
- Joined
- Aug 28, 2015
- Messages
- 46
- Location
- Centreville, VA
- Tractor
- Kubota L3240HST, Kubota RTV1120D, Kubota BX2380
I'm looking to get a second Kubota and wanted to see if you guys had any suggestions on what to get. I have a L3240 now with a FEL and it's fine for moving dirt and running the Woods bush hog. I got a 4 foot aerator from Everything Attachments and it works fine on the L3240 also, but that tractor has R4 tires, so when I run it with some moisture in the soil, it can leave tire marks (rear tires are loaded).
I also have a Scag zero turn with a 61 inch deck for mowing duties. Works great, but I would like to have a backup mower. The backup mower would also be used for keeping the grass cut on the trails on my property and for helping clear new areas (mainly grass). I could use the zero turn, but would hate to run over a rock or get it stuck on the trails. Could also use the L3240 with the rotary cutter, but it is sometime difficult to maneuver on the trails.
So I'm thinking about getting an older B series Kubota with a 5 foot mid-mount mower deck. Maybe a B7300 or B7500? Open to ideas, but I want no FEL, mid mount mower, turf tires, and ability to handle an 800 pound aerator on the back. The BX series seems too lightweight for my needs - both ground clearance on the trails and 3-point lift limits for that aerator. Am I thinking the right models for this use (B7300, B7500)?
