Subsoiler Modifications
/ Subsoiler Modifications #1
TwinWillows
WKY near Bardwell
NH TC40DA
My subsoiler did not dig deep enough soooo. I added some weights. To attach & easily remove them I added a hook to the back of the subsoiler.
Another view of the hook.
With the weights attached. As you can see they are barbell weights - 25lbs each.
Last pic. I like this mod because it was quick & easy & allows the weights to be simply removed & added. The subsoiler now burries itself all the way to the drawbar.
/ Subsoiler Modifications #5
50 pounds did the trick? When I hear add weight, man I think 200# or so. Piece of RR track. hehe
/ Subsoiler Modifications #6
One other trick to getting them to dig deep enough is to shorten the top link as it is dropped. As yours shows, when the 3pt arms drop the subsoiler tooth is pretty parallel to the cutting path (horizontal) when at a depth of about 8-10 inches. That means the tooth itself will not be pulling itself deeper, thus the need for weights.
I connect a chain between the subsoiler and the drawbar to pull on the lower shank at a point below the 3pt arm pins. This allows me to disconnect the top link, and makes for a more stable pull.
Just a different way to skin the 'cat' so to speak. /forums/images/graemlins/wink.gif
/ Subsoiler Modifications #7
My subsoiler goes deep enough to dig up my telephone cable three times so far. /forums/images/graemlins/laugh.gif This last time, the rototiller ripped it up, so I'm blaiming it on the phone company.
2024 CHUBBS GT-612/60 1T/A 12FT DUMP TRAILER (A67148)
2024 CHUBBS...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A64556)
2012 Ford F-450...
213065 (A64276)
213065 (A64276)
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
