MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,283
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Zoom Zoom?
I think I did, I bought a tractor and it didn't give me more than 4-5 inches of snow max for each storm ever since. That's liveable.Did you beat winter? I gave up and moved south.![]()
You would defiantly want to change the timing belt and water pump !! If the belt breaks it gets expensive to fix, real fast. If you are just a bit handy, it is not too hard of a DIY job. I have done a few from that era.My California Subaru. Not a spot of rust. I bought this new in 1999.
I was loading the other car (gets better mileage) to return to the ranch and noticed the Subaru, after its semi-annual wash, still looks great. So I took this photo today.
I'm trying to decide if it is worth putting $1k into the recommended and overdue maintenance - timing belt etc, valve cover gaskets, flush & replace all fluids. The head gaskets are original, a known trouble point for this engine. Also get the driver's door to respond to the remote.
It's at 150k miles now. Only used some 3k miles per year, it's tempting to just keep running it until something finally breaks. Like I have for the last 15 years.
I'm concerned that it could eventually need surprise expensive work, for example the exhaust system, that can be over $1k before considering replacing the cats. The transmission seems bulletproof.... 24 years is a long time for a car to simply run without needing anything.
At any rate I love my Subaru. We've taken it on many offroad adventures over the years. (photos).
Pull the fuse, maybe you could wire in an inline switch. You would think the dealer could program it out too!My wife has a 2019 Outback. She loves the car. 85000 miles and the only problem was the touch screen went out and had to be replaced.
The only issue I have with the car is the radio automatically starts when you start the car. Even if you turned it off before shutting it off. Annoying to me.
Anyone else have that issue and found a fix?
If libs started buying and driving AGCO tractors, does that reflect badly on the tractor?People in MY area that drive Subarus are mostly old ladies with Bernie Sanders stickers on the bumper.
Huh? I don’t get the analogy.If libs started buying and driving AGCO tractors, does that reflect badly on the tractor?
Personally, I drive what my experience, research and analysis say are the best vehicle for my situation. I don't worry to much about what other people think.
