Subaru Automobiles
/ Subaru Automobiles #163
We have some new ones that the smoke jumpers use when they work in wilderness areas. They are actually still available new.
True. They stopped building the Brat, but still make the Baja. If I had to have one or the other, I think I'd prefer the Brat.
Yep. I've seen them. They are not cheap.
I just hang these on the side of my shed. $32 was a great price.
Right out of high school a friend of mine had a Brat. As I recall, it was tiny! But it did great in the snow.
/ Subaru Automobiles #166
Less interior space, but more bed. I figure if a 'bed' is smaller than a typical trunk, it isn't worth it.
/ Subaru Automobiles #167
My California Subaru. Not a spot of rust. I bought this new in 1999.
I was loading the other car (gets better mileage) to return to the ranch and noticed the Subaru, after its semi-annual wash, still looks great. So I took this photo today.
I'm trying to decide if it is worth putting $1k into the recommended and overdue maintenance - timing belt etc, valve cover gaskets, flush & replace all fluids. The head gaskets are original, a known trouble point for this engine. Also get the driver's door to respond to the remote.
It's at 150k miles now. Only used some 3k miles per year, it's tempting to just keep running it until something finally breaks. Like I have for the last 15 years.
I'm concerned that it could eventually need surprise expensive work, for example the exhaust system, that can be over $1k before considering replacing the cats. The transmission seems bulletproof.... 24 years is a long time for a car to simply run without needing anything.
At any rate I love my Subaru. We've taken it on many offroad adventures over the years. (photos).
/ Subaru Automobiles #168
They have not made a Baja in 17 years, and they've got quite a following. The wife owned this Baja when we were married; we sold it to her parents a few years later, they've had it for a decade now. They live on the ocean and it inevitably lost the battle to rust, that's why it's a parts car.
I loved this thing, and it was an absolute blast to drive. It's only issue was the ridiculous decision on Subaru's part to make the Baja a 4 seater.
/ Subaru Automobiles #169
Sorry, I lost my mind. I failed miserably at the Google. There are a lot of 'speculation' sites that made it sound like the Baja was still in production.
I do agree that the 4 seater makes no sense in that small of a platform.
/ Subaru Automobiles #170
I have a 2021 Subaru Forester Touring and am delighted with it. I had a 2015 Outback before that was totaled by a careless guy in a truck, but immediately bought the Forester. I live at the end of a curvy, hilly mile-long gravel driveway and found most other car models simply can't take the daily rough us - Subaru can. And, as others have noted, it is superlative in the snow... Particularly with the new snow setting for the trans. Our experience with the Outback and our need for a respectable ground clearance dictated another Subaru after the accident. But my wife is fairly short so we went for the more expensive Touring option because the passenger seat can be raised or lowered and she is finally able to see out easily - which was important to her. The newer Foresters have outstanding windows, solid equipment and decent gas mileage. I have had no maintenance issues. I did have a tire blow but I patched it and that has held fine for a year. I do find it important to adjust my thinking when I drive my old F-150 without the lane functions, cameras and such - but I like the car a lot and don't know I could have gotten a better vehicle for my needs. And the dealer service has been great - in or out of warranty.
/ Subaru Automobiles #172
Yep, IMO they are now just a good all round vehicle, with great IIHS numbers, good visibility, good standard equipment, decent mileage, well designed AWD, and they stand behind what they make. They KISS by really only making one drivetrain and 2 engines for all their vehicles, and it seems the bean counters don't screw as many things up with cheap OEM parts as some of the other brands these days.
The high belt line and/or low roof line designs of other manufacturers may look a bit "better" or more "aggressive" but for the simple task of taking you and some stuff to places on less than perfect roads, subaru does it better than most.
/ Subaru Automobiles #173
My wife has a 2019 Outback. She loves the car. 85000 miles and the only problem was the touch screen went out and had to be replaced.
The only issue I have with the car is the radio automatically starts when you start the car. Even if you turned it off before shutting it off. Annoying to me.
Anyone else have that issue and found a fix?
/ Subaru Automobiles #174
We have that 'feature' on our '18. I haven't figured out a way to change it. Annoys me, too. I always turn off radio, fan, etc.
We also had the faulty touch as screen. No issues since they fixed it under warranty.
Try
this:
lso, meant to tell you about another interesting feature this "radio" has. Even AFTER the dealership reprograms your system, be aware that when the radio is on and the engine is on, the radio will remain on for about 15 seconds AFTER you shut the engine down (unless you completely shut the radio off before shutting the engine off). AND unless you have turned the radio off completely BEFORE you shut the engine down, the next time you start the engine the radio will still turn on automatically. So in order to prevent the radio from turning on automatically you must push and hold the left hand button (4-5 seconds) until the touch screen turns off and the radio turns off simultaneously, then shut the engine off. PLUS, if you open the driver's side door during the 15 seconds after turning the engine off, the radio shuts off, but will automatically turn on again when the engine starts. So the moral to this story is this, after your info-entertainment system is reprogrammed, the ONLY way to prevent automatic turning on of the system, is to be sure to push and hold the left hand button until the touch screen/radio shuts off BEFORE shutting the engine off. Forgive me if this is confusing or sounds like I'm repeating myself, but the dealership and Subaru of America tech reps were of little to no help in figuring out this problem. None of this information can be found in the manual for the info-entertainment system either. I'm one of those geeks that reads manuals, so I found it frustrating when it (manual) and Subaru were no help. Hope all this helps.
/ Subaru Automobiles #176
The radio staying on after you turn it off is a feature (the A6 had the same thing). I guess so you can finish listening to the song or news story or whatever. Not a fan of it starting back up again.
Thanks! I'll have to try this out next time the Mrs. is in town with the Outback.
/ Subaru Automobiles #177
Why Forrester rather than another Outback?
I prefer forester over the outback. Don’t like the big touchscreen. I like knobs for things, radio, tuning, ac controls.
Would have bought another forester last year if dealers had them, got Mazda cx5 instead. Sitting in mine now waiting on my son.
/ Subaru Automobiles #178
The Forester looks a little more roomy in the cargo area. Maybe that’s just an illusion? But since I am a forester, it was the natural model for me to buy. 😊
It is an illusion. The Outback has slightly more both behind the rear seats and with the rear seats folded down. ;)
/ Subaru Automobiles #180
I had a Mazda CX-5. Bought it for the kids When they started driving. Best small car I ever owned. Really fun to drive.
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Parker 500 Auger Wagon (A66285)
Parker 500 Auger...
1992 Rammax Trench roller and Extra Set of Drums (A62613)
1992 Rammax Trench...
