Tires Sub CUT tires...
/ Sub CUT tires... #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
This one's for all the Sub CUT owners out there who do a lot of dirt work. My tractor came in with the turf tires, and because the tractor is such a new model, my dealer wasn't able to get it with the bar tires and still can't get them from Case yet. I'm noticing that when doing a lot of dirt moving with the FEL, those turf flotation tires seem to do an awful lot of flexing and squooshing around. The traction has been fine so far, as I stay out of the dirt on rainy days. But I know from past experience that at some point, traction will become an issue with those tires.
For those of you running unfilled bar tires in the 18-8.50-8 and 26-12-12 sizes, do you notice that same amount of flexing of the front tires when moving a full FEL around? I'm thinking of trying a set that my neighbor took off his BX22. I also want to see how they do mowing. I'm not sure I'll be able to keep them (if I like them) as he would like to keep them around for when he may need them, so if they do work, I may need to get my own set.
/ Sub CUT tires... #2
I just have turf tires on my bx2200. I have been doing mostly dirt work with this tractor. I had some traction problems when pulling up an old gravel drive way with my FEL and box blade. I added some rear tire chains and that made a big difference with traction in the mud. I run about 12 lbs of air pressure and the fronts do flex a little, not sure this is a bad thing. Some owners also have two sets of tires and rims. A set of rear tire chains will run around $100, new set of tires and wheels around $300-350.
Dave
/ Sub CUT tires... #3
I have both turf and bar tires for my BX22, and have never used the turfs. I have the rear tires filled with beet juice and have never had a problem pushing or pulling anything with them. I see no need for tire chains to date, but when I install the snow blower this winter, I will find out how well it handles. I have a rear weigh box filled with 600 pounds of lead for ballast when using the tractor without the hoe installed. The front tires do flatten out a little when the loader is filled with rocks. No problem at all with just dirt. The BX uses 4 ply rated tires. I know that you can purchase both 6 & 8 ply rated tires for the front, but the price is steep for the extra plies. I have not had many problems with the bar tires on the turf as long as the turf is dry. If I go onto the turf in the early morning when the grass is wet from dew, it can easily be damaged and tufts pulled out. If I were to have only one set of tires, it would be the bars. If I ever finish all the backhoe and loader work, I will put the turfs on for grass cutting. I intend to hydro seed in the fall a couple of acres, so I will probably have to have the turfs on for the initial first few cuts of the new grass.
/ Sub CUT tires... #4
I only have turfs on my TC18, with a full FEL I've had them flatten out to the point where I can just feel rims hit the ground on the bumps. I haven't broke anything yet, but it doesn't seem that that would be too good for the sidewall of the tire.
/ Sub CUT tires...
My front turfs are also 4 ply. The rears are nice and stiff, and I have no real complaints about them. But last night while doing some digging and turning with a full loader on uneven terrain, I got a bit nervous when I saw what the front tires were doing.
I initially thought one of the tires was going flat, but it was at 21.5 psi when warm. The max cold is 22, so I inflated them to 23 (they were pretty warm by then) and the flex lessened significantly. I think I'll have to keep them right at 22psi cold for loader work. If I do switch over to the bars, I figure the turfs will have to go back on for a while this fall when I lay a bunch of grass seed down and start mowing the new grass.
Sounds like even the front bars flex a bit with a good load in the bucket. Maybe I just need to get a 6 ply turf tire for the fronts. My neighbor and I have been considering buying a set of rims to put the extra set of bar tires on, then we can both swap out the bars whenever we need them. Guess I have something to think about.
/ Sub CUT tires... #6
<font color="blue"> Sounds like even the front bars flex a bit with a good load in the bucket. Maybe I just need to get a 6 ply turf tire for the fronts. </font>
Another option might be to get the front tires foam filled.
The foam would add a little weight, but not that much since the tires are pretty small to begin with. I have the fronts on my B2910 foam filled and like the result. They are R4s though...
It is possible you could fill the existing turf tires for less than buying something with a stiffer side wall. And you would never have to worry about a flat or the tire bead coming off the rim under heavy load... /forums/images/graemlins/cool.gif
I guess you can see I am real happy with the foam filled front tires on my B2910... /forums/images/graemlins/smile.gif If I had a loader on my BX I would probably fill the front tires on it as well...turfs there...
/ Sub CUT tires... #7
Do the foam filled tires flex and cushion like air filled tires or are they just round and hard??
/ Sub CUT tires... #8
<font color="blue"> Do the foam filled tires flex and cushion like air filled tires.... </font>
I don't think they cushion like air...but there is some give to them and there is a little bounce to them.
Hard for me to say more because I got them foam filled the second day I had the tractor. Glass down back was too much for the the front tires to deal with...guess it was the local dumping spot back back when there was no garbage pickup years ago...
I am thinking of getting a set of bar tires for the bx and foam filling all four, for the sake of greater stability on my back hillside...even though the BX seems real stable as is...
Now I am wondering if I spelled stable right...one of the perils of answering a junkman question perhaps? /forums/images/graemlins/grin.gif (may be an inside joke... /forums/images/graemlins/blush.gif)
/ Sub CUT tires... #9
</font><font color="blue" class="small">( I run about 12 lbs of air pressure and the fronts do flex a little, not sure this is a bad thing. )</font>
The many articles I've read on this subject say that it's good to run a little low/correct as long as you have radial tires, but don't do it with bias ply tires as the sidewall won't hold up. Only run Bias Ply tires at full recommended PSI. John
/ Sub CUT tires... #10
stable = Resistant to change of position or condition; not easily moved or disturbed: a house built on stable ground; a stable platform.
Stabil = The fuel preservative /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Sub CUT tires... #11
I don't believe that these size tires even come in radials. Radial designs are usually reserved for highway use tires.
/ Sub CUT tires... #12
</font><font color="blue" class="small">( I don't believe that these size tires even come in radials. Radial designs are usually reserved for highway use tires. )</font>
There are radial tractor tires, and they can be run lower. Most smaller tractors have bias ply and should not be run low. John
/ Sub CUT tires... #13
No question about there being some tractors that will come equipped with radials, but we were referring to the small sub compact tractor tires in this thread.
/ Sub CUT tires... #14
</font><font color="blue" class="small">( Radial designs are usually reserved for highway use tires )</font>
Sorry Junkman, it was this statement that threw me off. John
/ Sub CUT tires...
Well, I can tell you that running these front bias tires even 2-3 lbs low isn't good for them with a load. /forums/images/graemlins/shocked.gif It's amazing how much sturdier the rear tires are compared to the fronts. Those little front sidewalls were folding over and creasing like crazy with a load of heavy moist dirt in the loader.
I'll have to look into the foam option. Hopefully there are a few different densities available, because the last time I had that done, it was for a forklift, and I know that particular foam would be like 2 rocks (remember the Flintstones? /forums/images/graemlins/grin.gif) on the front of a Sub CUT.
/ Sub CUT tires... #16
</font><font color="blue" class="small">( Well, I can tell you that running these front bias tires even 2-3 lbs low isn't good for them with a load. It's amazing how much sturdier the rear tires are compared to the fronts. )</font>
That is exactly what I've been saying. Bias tires running at low pressures can fail due to side wall destruction. As a matter-of-fact, most of the articles mentioned adding a little air to the maximum stated if loads are going to be excessive. Junkman is not disputing any of this either. He's only saying that most small tires ARE bias ply tires, not radials that can be run low. John
/ Sub CUT tires... #17
on a 2210, the suggested front pressure is 22, and in the loader manual it suggests adding 5 extra ponds of pressure when attaching the FEL. Might be worth checking the specs for loaders being attached versus off and seeing if other manufacturuers have like suggestions /forums/images/graemlins/wink.gif
/ Sub CUT tires...
</font><font color="blue" class="small">( As a matter-of-fact, most of the articles mentioned adding a little air to the maximum stated if loads are going to be excessive. )</font>
Good, cause even though the sidewall recommends 22psi cold, I was thinking I'd like to bump it up to 24-25psi cold. I figured there's less of a chance of blowing the tire due to a few pounds overinflation, than blowing it apart by rolling or folding it right off the rim while turning with a heavy load.
Besides, I usually don't care much for OEM tires on my vehicles, so I guess if I trash the OEM tractor tires, then I'll "be forced" to buy some better tires. /forums/images/graemlins/cool.gif
/ Sub CUT tires... #19
</font><font color="blue" class="small">( on a 2210, the suggested front pressure is 22, and in the loader manual it suggests adding 5 extra ponds of pressure when attaching the FEL. )</font>
That certainly sounds reasonable as those bias ply tire sidewalls just don't have the rigidity of a radial side wall. Max pressures are puposely low anyway and there's a safety range built in that will go higher. 5 pounds extra sounds fine. John
/ Sub CUT tires...
Ok, so it looks like I have to buy a new set of Bar tires, as the old Maxxis PowerLugs that my neighbor took off his machine are too damaged.
My dealer recommended I go to a tire shop if I want the tires only, and it looks like the Carlisle SuperLugs only come in an 18X9.50-8 front, as opposed to the factory 18x8.50-8's. The only supposed difference is the width, the rolling diameter is the same between the two.
Maxxis makes the 18X8.50-8's, but the tire shops are having no luck in getting through to them. So, can I go with the Carlisles that are 1" wider than the OEM Maxxis PowerLugs without doing damage to my MFWD? The new fronts (in the 1" wider size) and the new rears only have a .4" difference in rolling diameter compared to the OEM Maxxis turfs that are now on my tractor, so the numbers are telling me everything will be ok.
Does anyone disagree? /forums/images/graemlins/confused.gif
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
Lot of 4 12-16.5N.H.S. Skid Steer Wheels and Tires (A59228)
Lot of 4...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
