Sub-compact rear question
/ Sub-compact rear question #1
brentagade
Columbus, MS
Besides a Husqvarna Riding Mower, none at the moment but in the market for a sub-compact
Greetings,
New to the forums and in the market for a sub-compact. I have a question about swapping rear implements. I was under the impression that going from backhoe to a 3-point implement was a fairly "easy" swap. Is this really the case or is it a much more involved swap? The backhoe, while a nice add-on is a little further down the chain that others. I know you can get the 1025R with or without. I'm sure it would be a getter deal to get it with, but if I were to get it without, is it a much more involved process to mount it up?Any info would be greatly appreciated.
Thanks!
/ Sub-compact rear question #2
I don't know about the 1025 but on my much larger 3320 the hoe goes on/off quickly, probably around 5 minutes each way. Removing or attaching the 3 pt. arms and top link (which is required on my tractor) probably adds maybe another 5 minutes. Not a big deal once you've done it a few times.
/ Sub-compact rear question #3
Greetings,
Thanks!
The only issue with getting the BH later would be putting on the sub-frame / mounts. Labor intensive and heavy parts. Most people take the tractor to the dealer to have everything installed, adding cost. You ussually do get a better deal getting the hoe with the tractor purchase.
/ Sub-compact rear question #4
I’ve never dealt with a little tractor backhoe but it was easy on mine. Under 10 minutes each way including the time to put the 3pt arms on/off.
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
3144 (A63117)
3144 (A63117)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2021 Ford Explorer SUV (A66738)
2021 Ford Explorer...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
