Buying Advice sub compact or compact tractor?
   / sub compact or compact tractor? #41
I would advise anyone to consider the LS tractors. Huge bang for your buck. The J2023 is sized like a Mahindra max. It's a beefier, bigger SCUT or small CUT. In its class, I've yet to see anything that can match or beat the specs. 23HP, 9.2gpm hydro pump, 1270lbs of loader capacity, 5 year warranty, and priced at $12,200. To get that kind of loader capacity and size hydro pump, you'll be spending close to $15k with other brands and getting a shorter warranty.
I checked the Mahindra Max 25 and for only 2 more HP, you get less loader capacity and a smaller hydro pump. The loader joystick felt cheap and looked cheesy to me, and every Mahindra I've seen seems to fade to a pink color quickly. And the Max 25 was about $3000 higher priced.
   / sub compact or compact tractor? #42
Then buy it.
   / sub compact or compact tractor? #43
Murph------ You are getting wordy, again.
Are you stalking Me?
Well he said it was a great deal. Then Buy it before you try to sell it.
   / sub compact or compact tractor? #44
I probably will be buying one. I was also sharing for the benefit of the OP and any others who are considering similar sized tractors.
   / sub compact or compact tractor? #45
I will be interested on what you think of it when you put on some hours. Don't get me wrong, I like Blue.:eek:
   / sub compact or compact tractor? #46
I'll be buying something in the next month. Top contender is the J2023, but I'm also considering a new old stock 2012 Bobcat CT225. $1800 more than the LS, but a much larger size tractor.
   / sub compact or compact tractor? #47
The Bobcat is a Kioti in white.
   / sub compact or compact tractor? #48
I know. The CT225 is essentially the CK27. But a 2014 CK27 is $16k and a new old stock 2012 CT225 is $14k.
   / sub compact or compact tractor? #49
Sounds like a good deal.
New Bolt on Receiver (A59000)
New Bolt on...
SARLO MOWER (A55758)
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56435)
J and L Cargo...
NEW Landhonor LHR=EPC40 Plasma Cutter (A59000)
NEW Landhonor...
