Buying Advice sub compact or compact tractor?
   / sub compact or compact tractor? #71
I just took a look at the Kioti CS2410 on the web. It looks like a good unit. My only reservation is the post hole digging. But I'm not saying it wont do it, I just dont know that it will.
My only concern with that would be the lift height of the 3pt ... I drilled a bunch of holes with my CK20, and it did a good job power wise (though I almost buried it a few times). HP is comparable between that and the CS2410 but I'm assuming the 3pt lift height was higher.
If I decide to go SCUT I will make sure the dealer shows me how to hook up the post hole digger and box blade and that it will work satisfactorily for me before I would ever sign the papers. It would be great if it works but if it doesn't I'm not wasting my money.
   / sub compact or compact tractor? #73
I am planning on having them drop a cs2410 off for me sometime in the summer to try it out at my house with my soil and me running it. If a larger tractor is what I need then I am willing to wait but if the smaller tractor will do it and still last with minimal problems then obviously I want one sooner then later :)
As for the pond I'm not thinking big just maybe as I need dirt for this and that, take out a scoop and eventually there will be a pond. Also for digging I was thinking to break the soil up with the box blade first then scoop out the dirt? maybe a bit time consuming but easier on the tractor?
Why don't you rent a machine for the pond?
I think the CS2410 has a limited cat 1 hitch. If he gets a PHD for a SCUT he should be fine.
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
Bucket (A55973)
Bucket (A55973)
2011 TOYOTA Prius (A56859)
2011 TOYOTA Prius...
260145 (A56859)
260145 (A56859)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
