Stupid, Stupid, Stupid Battery Troubles
   / Stupid, Stupid, Stupid Battery Troubles #31
I've had an antler pierce a steel belted truck tire.. and I've had a rib bone my dog was chweing on and left int he field go thru a large front tire on my NH 7610s...
soundguy
That one take the cake for me. I once had a Fork in my 2007 F-150. It put 4 tiny holes side by side by side by side. I also had a Dogs tooth or some critters tooth in the tire of a S-10 Blazer I had.
That truck was new and I could not get the lugs off. I walked to a farmers house and ask to use the phone so I could call my dad, did not have a cell phone back in 91. He said he would bring over a bigger breaker bar. Well the farmer got a 6' section of pipe and drove me out to my truck and about that time my dad showed up with a breaker bar and some sockets, 3/4" drive. We could not even get 1 lug off even with us all jumping on the bar and pipe so we tried putting the jack under the bar and all it did was lift the truck off the ground.
It was a Sunday and my dad was mad so I drove the truck to the Chevy lot with my dad behind me and his flashers going. It was about 7 miles and it tore up the tire and aluminum wheel. The next day I gave them a call and they told me they destroyed all 4 wheels getting them off and had to order new ones and a tire. If I remember right they had to use a torch to burn some of the lugs off.
Chris
   / Stupid, Stupid, Stupid Battery Troubles #32
IMHO.. I'd always leave frame ground connected. Install the cutoff in the posive line.
ever notice fuses always got inthe 'hot' side.. as well as switches.. ground is almost never switched except in full isolation cases where both poles are switched out of circuit.
soundguy
I fully intend to install some kind of a battery shut off switch. I've proven to myself that any kind of "be sure and check everything when you're done with the tractor" kind of I'm hoping to get some guidance from first hand experiences, though.
Harbor freight has one for $4 that looks for all the world to be just like everyone else's switch... Harbor Freight Tools - Quality Tools at the Lowest Prices
Anyone actually installed these? What kind of tricks make it easier to install or use?
Where my negative battery cable is right now is a little hard to access. I'd have to pull the side panel of the tractor to get to it every time I wanted to run the tractor. Would it be a good idea to re-locate the negative terminal to make this switch easier to get to?
   / Stupid, Stupid, Stupid Battery Troubles #33
"Give me some more details about what you did with these trickle chargers. Which chargers were they? Do you have the item number? How did you hook them up to the connectors? Did you hook the other side of the connectors directly to an extension cord?"
I use this Harbor Freight Tools - Quality Tools at the Lowest Prices HF charger with a two prong version of one of these.http://www.trailerpartsdepot.com/itemdesc.asp?ic=002220&eq=&Tp= One side of the cable is attached to the battery and feed out from under the seat to an out of the way place where you can still get to it, then the other side is spliced into the trickle charger side.
Works really well, Dave
   / Stupid, Stupid, Stupid Battery Troubles #34
Warning: This is a rant. There is no useful information in this post.
I must be doing something wrong because I go through batteries faster than anyone I know. I'm sure I must just bump some switch or lever on occasion that puts a gradual draw on the battery until it's dead and stays that way for a week destroying the battery. On my last tractor I replaced the battery just about every winter. Luckily, I had a good relationship with the guy at the parts place, and I could get it warrantied every other year.
I had hoped that with my new tractor I wouldn't have the same problem. Not so. A few weeks ago, I went to start it and the battery was dead. This battery was new with the tractor in March of 2008. Not only was the battery dead (No voltage), but when I hooked up the charger, It tells me the battery is all charged. It must have a dead cell or something. I know I must have left the ignition on somehow even though I know I have a problem with that and check it every time. My hour meter went from about 540 hours to 920 during the time the tractor was sitting before I found the dead battery.
I put the battery from the old tractor in the new one (it was only a year old since I'd just replaced it the winter before) and the tractor worked fine for a month or so. This past Saturday I started the tractor and ran it for a while to plow mine and my neighboors' driveways. This morning (three days later) I got up early to plow again and the battery was once again dead as dead. Once again, I pulled it out and the charger again says that it's fully charged.
I know the charger is good because I do use it occasionally to charge other batteries and it works.
I'm taking the newest battery (the one that came with the new tractor) to the John Deere dealership today since it's a John Deere battery. I hope they'll warranty it since it's only 8 months old. Then I'm going to get a battery shut off switch and maybe even an onboard battery maintainer.
Simple solution...
https://www.wholesalemarine.com/blue-sea-systems-e-series-battery-switch-selector-4-position.html?gclid=EAIaIQobChMIr7fYvt2q5QIVXB6tBh1s9gYzEAQYBCABEgKI1_D_BwE
   / Stupid, Stupid, Stupid Battery Troubles #35
Holy necro'd thread Batman.
This guy posted this 11 years ago...
   / Stupid, Stupid, Stupid Battery Troubles #39
Or simply add a Solenoid, and a couple pieces of wire, tie to RUN side of the keyswitch. Then battery is only connected when the key is in RUN and START mode. Turn the KEY off and battery is disconnected. If you must you could add a toggle switch, then battery stays disconnected until you toggle the switch.
I've eaten a lot of batteries myself, my solution is a 'Solar Battery Tender' with a cigarette/PowerPoint end. Add a plug to Tractor, etc. Pull in, plug in Charger.
Many easy ways to solve the OP issue.
Max
   / Stupid, Stupid, Stupid Battery Troubles #40
Old post but NEW problem to a person with the same issues. Do battery issues ever go out of date?
Now if he was posting about a broken buggy whip then no help would be needed.
Quick Attach Stump Grinder Mini Skid (A56436)
Quick Attach Stump...
set of 4 tractor trailer tires Roadforce (A56436)
set of 4 tractor...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A57453)
IMPORTANT PLEASE...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2017 Ford F-250 (A55973)
2017 Ford F-250...
