Stupid mistake
/ Stupid mistake #1
BrentD
Well, spent most of the day Monday running the little dozer working on our pond that we're rebuilding. All went well until I went to park the dozer back under the shed. The shed is pretty much an extension of our barn roof. It's bolted to the barn at one end and has five 6-inch posts holding up the other end. The cattle trailer is parked under the shed next to the barn so the dozer is a bit of a tight fit. The cutting edge of the dozer blade has "wings" that stick out about 6 inches on both sides of the blade. I was going as slow as possible keeping a close eye on the right side to make sure I didn't snag the trailer when all of a sudden I hear *SNAP* *BANG*. I immediately yanked the gear shift into neutral and hit the brake, but the damage was done. The tip of the left blade wing snagged the second 6" post and snapped it like a toothpick.
Fortunately the shed is fairly well built so it didn't come crashing down on top of me. Was also glad there was only one bolt through the top beam into the post, otherwise the breaking post would have twisted the outer support beam and caused major problems, possibly including bringing a section of the roof down on my head.
Guess the moral of the story is be very careful when you're working in tight quarters. Bad things can happen a lot faster than you can react.
/ Stupid mistake #2
The piece you are calling a wing is the ''corner bit'' Now you have learned two things from your little accident.
Sincerely, Dirt
/ Stupid mistake #3
Glad you're around to share the story...
Don
Case 75 (A64911)
Case 75 (A64911)
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
Polaris Ranger 150 (A64912)
Polaris Ranger 150...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
LeroI 185 Compressor (A64911)
LeroI 185...
