Stupid Hydraulic ?
/ Stupid Hydraulic ? #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I'm making a thumb for my backhoe. It's gunna be a Pin on. The cheapest part for me is the fabrication. I want to make it Hydraulic but that's where the cost seem to get pricey. My stupid question is , How come when I use my portapower I can jack out the cylinder and when I release the pressure it returns. I was thinking maybe for a quick temp Idea. I could use a porta-power to control the thumb, Pump it out and let it retract. I know if i use a regular thumb cylinder I have to run 2 lines since it is dual acting. Just kicking thoughts around in my head.
/ Stupid Hydraulic ? #2
What is stupid about the question?
I'd imagine that there is a spring to return the "portapower" (whatever that is :) ) and if the spring is heavy enough, it might return the "thumb" on the hoe.
Maybe that is a stupid answer. :D
/ Stupid Hydraulic ? #3
Have you thought about buying a stationary thumb welded to the inner boom which will close over the bucket when it is fully retracted (curled in) under the dipper boom?
/ Stupid Hydraulic ? #4
There are also thumbs that will close as the bucket is closing. It is hinged to the bucket and the dipper arm.
If you have the hydraulics for a double acting, then why not use it. You can get new or used cylinders at a decent price. You can build it stationary for now and add hyd later.
/ Stupid Hydraulic ? #5
The return spings in these are very weak......if you use this you'll need a couple external springs for pull back that will hold the thumb w/o flopping around:2cents:
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
