Stupid Hydraulic ?
/ Stupid Hydraulic ? #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I'm making a thumb for my backhoe. It's gunna be a Pin on. The cheapest part for me is the fabrication. I want to make it Hydraulic but that's where the cost seem to get pricey. My stupid question is , How come when I use my portapower I can jack out the cylinder and when I release the pressure it returns. I was thinking maybe for a quick temp Idea. I could use a porta-power to control the thumb, Pump it out and let it retract. I know if i use a regular thumb cylinder I have to run 2 lines since it is dual acting. Just kicking thoughts around in my head.
/ Stupid Hydraulic ? #2
What is stupid about the question?
I'd imagine that there is a spring to return the "portapower" (whatever that is :) ) and if the spring is heavy enough, it might return the "thumb" on the hoe.
Maybe that is a stupid answer. :D
/ Stupid Hydraulic ? #3
Have you thought about buying a stationary thumb welded to the inner boom which will close over the bucket when it is fully retracted (curled in) under the dipper boom?
/ Stupid Hydraulic ? #4
There are also thumbs that will close as the bucket is closing. It is hinged to the bucket and the dipper arm.
If you have the hydraulics for a double acting, then why not use it. You can get new or used cylinders at a decent price. You can build it stationary for now and add hyd later.
/ Stupid Hydraulic ? #5
The return spings in these are very weak......if you use this you'll need a couple external springs for pull back that will hold the thumb w/o flopping around:2cents:
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
New - Front mount rototiller
New - Front mount...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
213063 (A64276)
213063 (A64276)
2022 EZ-GO ELITE...
