Stump removal....
   / Stump removal.... #1
mrcaptainbob
Platinum Member
Jackson County, Michigan
Bolens HT-20
I saw a thread in the recent past about pouring some concoction into drilled holes in a stump that accelerated it's demise. It was a two step process whereby the second step was to ignite some 'fluid' poured in the holes and it smoldered it's way through the stump including roots! Well, I'll be dipped if I can find it. Was it on TBN? I will look else where, too.
   / Stump removal.... #2
Stump removers basically add nitrates to accelerate the rot. I read somewhere about Amish trick to pile up manure over the stump for a year or so.
Sorry can't help you with your missing information:(
   / Stump removal.... #3
Never tried it myself, but have heard of people pouring diesel down into the stumps for a few days until saturated and then igniting it. :thumbsup:
   / Stump removal.... #4
yep - BT-DT. Used metal jar lids loosely nailed to the center of the pine stumps. Punched a couple of additional small holes in each and filled them with diesel. Set up about 200 of these to clear out an area where I'd cut a stand of pines. Every few weeks I'd try to lite them. They'd burn just about as long as the fire had diesel in the lid, then go out.
After 2 years of trying to lite them and get them to burn, I finally had 'em ground out with a stump grinder. Maybe I was doing something wrong? But I sure didn't have any luck trying to burn out stumps.
I do have some more to get rid of, so if there's a trick, I sure want to learn what it is.
   / Stump removal.... #5
I think it's all in the dance after one poors the product into the holes. I believe ya have to dance around in a skirt made of the same leaves {or needles} as the stump you're trying to get rid of. I believe it also helps if ya get a bunch of friends over to join in on the dance.
   / Stump removal....
Yeah, nitrates. That was one of the ingredients. As for a skirt made of the pine needles/leaves...that may work, as the last method obviously didn't. Grass skirts....well, better'n nuthin'!! Maybe there should be more than just the ten of us???
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2010 International 4300 TMA Attenuator Truck (A52377)
2010 International...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
