Stump grinder build Idea.
/ Stump grinder build Idea. #1
xrjohndeere
Mo
2021 Kubota L4060 HST
I have been cutting wood and fighting stumps.. I decided I am going to build a stump grinder. I could buy one but what is the fun in that. Let me run this idea by you guys and see what you think. This is my plan. I am going to use an old manual flywheel off some sort of big engine.. As I recall most of them are about half to one inch thick. This will save me the trouble of cutting and truing a wheel.. I will drill and tap the flywheel for replaceable cutter teeth on the mill. I need help in locating the gear box. My buddy has a woods, I might just use the same gear box on a pto slip clutch. I considered using a hydraulic motor but I am pretty sure the JD 4520 will not have enough hydraulic flow to do much good.
I want to build the grinder so it hooks up like my backhoe onto the backhoe mounting plates. I am going to build a platform like my backhoe with the out riggers, seat. ,etc. I am going use the power beyond hydraulics to run a hyrdaulic valve system just like my backhoe so I can run the cutter up and down, side to side, and in and out. I want to be able to set up in one place and cut the whole **** stump without moving. I know there are a lot simpler setups but I want something that is different, easy to use and functional. I can not tolerate having to set in the tractor seat and look behind me like a regular 3pt implement. Ok what do you guys think? I know this is going to be a big project but it will be interesting. Let the ideas fly.
/ Stump grinder build Idea. #2
Can't help with any ideas, that's over my head. When you get it built, I have some hedge stumps that need grinding. :)
/ Stump grinder build Idea. #3
It would be nice if you could find an old stump grinder for scrap and salvage some of the components, like the cutter wheel, drive assembly, etc.
Please keep us posted with lots of comments and pictures.
/ Stump grinder build Idea. #4
I've built one about 6-7 yrs ago.It's got a gear box off some sort of old implement,Not sure what it's off as my neighbour had it laying around and gave me a bunch of stuff when he was cleaning up his yard.Anyway I made it fit onto the back of my MF 1655 3 pth with pto rpm of 1800. I think it's about a 2-1 ratio so it whips the blade pretty good.For the bale I used one 3/8" x 12" round plate and one 1/4" x 12" round plate. I then sandwich 6 carbide lathe bits between the plate's. I need to use 3 right and 3 left bit's. Leave two straigth,bend two one way and two the other way. They are also not only sandwished between the two plates there also sandwiched between two 1/2" square rods on each side which keeps them in place,There's a 1/2" hole drill thu both plates and part way thu the bit as well like a notch in the bit to keep it from flying out. Have a guard build right around the wheel as well for protection. Have used it on hundreds of stumps over the yrs'. It's moved by tractor movement back and forth as well sideways and lower and raise on the 3pth. Going to change it this spring going to mount it onto the front my my MF gc2300 going to make a side shift so that all I'll need to do is move the tractor back or forth and use the side shift for side to side and with it being mounted on the front quick hitch that'll raise and lower it.I haven't any pictures of it but once it warms up and I get to it I'll start taking and posting.Larry:D
/ Stump grinder build Idea. #5
Thanks for all the good ideas!!!!
This has me thinking about that 5' shredder that my tractor can't lift or use........
Hmm, remove gearbox, rotate 90*, install wheel with teeth = WHAMO! Stump grinder.
/ Stump grinder build Idea. #6
Take a look at Green Manufacturing for your tooth and pocket selection. Green Manufacturing
/ Stump grinder build Idea. #7
xrjohndeere- hmm interesting idea. First off- I want to state I have a kubota with simalar setup as your JD. The only issue I see is how are you going to transfer power from PTO through the frame of BH to the stump grinder?
Perhaps you can still look into the hydraulic motor idea? just remove the bucket and attach a motorhead connected to a cutterhead. Instead of worrying about the ability to have enough flow, why not size up the cutter head to the flow rate? 4" cutter maybe? granted it may not be as bigand fast you like, but it would get job done. ;)
/ Stump grinder build Idea. #8
Massey driver,
Can you post some pictures or your machine?
It sound's like yours is quite robust.
/ Stump grinder build Idea. #9
Sorry, somehow I read over your comment about posting pics later.:D
/ Stump grinder build Idea. #10
I don't know how big a wheel you are looking for, but the wheel out of an old ensilage chopper might be a good start. Mine is fairly large in diameter but it seems you could replace the cutters with teeth...
/ Stump grinder build Idea. #11
It wasn't to cold of a day so moved some stuff out of the way and took a couple pictures.This gear case as you can see I have a spare piece for it.Whats unique about this is that it has a over run clutch built right into it.If you look close near the guard you can see a rod sticking out that at one time must have had some kinda of linkage to shift it into netural of drive.I have the guard holding the shifter in gear all the time.But that doesn't affect the over run clutch so in away it's pretty good to have.I can idle the tractor right down and the over clutch takes over and lets the cutting wheel slow down on it's own,not affecting the tractor at all.No idea what this gear box was off[maybe some sort of old hay binder] all I know is that it works excelent.The person who had it before me had tried making a 3pth post hole auger.He had welded two different size fligthing onto each of the long pieces,I've cut them off and used one for the stump grinder.I do know when I put it onto the tractor[when it was still a auger] that thing turned like crazy.Bet thats why it was never used for post hole digging.It's something like 1 1/2 times faster on the output then the input shaft.So for a stump grinder it works just fine.Anyone have any idea as to what this gear box is off of??? It's got MH cast right into the cast housing.So its pretty heavy even with it grinding it doesn't bounce hardly at all.It's not something you want to try and lift and put into the truck to often. Sorry about not showing the wheel and teeth but you can't really see them with the guard in place I used a old air plane tire for the side guard its sandwiched between 2 plates of 1/8" steel.Don't want anything flying out and hitting me the operator while it's being used.Using the tire allows the wheel to be completely covered in from the side yet still flexable to give and be out of the way while grinding.Haven't had any problems.Had to change the teeth only once since making it.I have lots of stones etc: and sometimes the stump is grown into a stone so all in all I'd say its stood up pretty good.By the way its ground out 200 plus stumps over the last few years,now its getting used less as I only need to grind out stumps when we lose tree's. Larry
/ Stump grinder build Idea. #12
Massey Driver,
Thank you for taking the extra effort to post pictures of your machine.
It is not quite what I expected, but it sounds like quite a unit. Especially after chewing up over 200 tree stumps.
/ Stump grinder build Idea. #14
David,
Thanks! That's about what I had envisioned turning my shredder into, but your simpler design has given me ideas and hope!
Thanks for all the feed back guys. When I get a chance and a little better weather I will post some pics of the dump trailer I made. Shortly after I completed the trailer it was rearend by an 18 wheeler. Done I pretty good number on the trailer. I will post some pics of the damage and pics after I fix it. I am waiting to get it on the frame machine at votech to straighten it out. The trailer was pulled home. The 18 wheeler was towed off with a lot of damage. It was undrivable. The driver wasn't paying attention and smacked the trailer doing about 45mph. Spun the trailer and truck around 360 degrees. My nephew had borrowed it. Lucky he wasn't hurt.
LOOK! (A65640)
LOOK! (A65640)
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
