Stump drager
   / Stump drager #4
... okay, I'll bite.
What's a stump dragger?
... hoping it's not like a henway or a diquefer ...
   / Stump drager #7
Leave the trunk 6' tall so you can use it as a lever then get busy w/ the BH. Works every time...
   / Stump drager
No its a serious question but it would be a good one like headlight fluid. I used a chain with my truck hook snapped busted out back window that was my dumb *** attact lucky it hit on pass side here one though. Have you ever noticed that anybody driving slower than you is an idiot and anyone going faster than you is a maniac ;)
   / Stump drager #9
<snip>
Have you been talking to my Dad?
About the stump puller - I have been having good luck on hardwood stumps about 8 inch diameter and under using subsoiler. I hook the point under the stump & lift with the 3pt. I haven't had much luck with bigger game and haven't given them a serious effort with the tractor.
Artisan's method sounds like it would work, too. Use the 6 foot trunk as a pry bar. Just be careful how you attach to your tractor. In general, I like to use a heavy rope with a snatch block so I'm not in the line of fire if there's a recoil when there's pulling to be done.
   / Stump drager #10
stump puller, or stump dragger?
if you are wanting to pull stumps. do a search here on TBN for A frames and tree puller, along with chain chokes. put metal A frame up near tree. run a chain around bottom of tree and up over A frame, and then down to tractor or truck. the A frame transfer forces of pulling horizontal to vertically, and pulls up on the tree vs side ways.
if you leave say 9 feet of trunk on bottom of the tree, you can use place chain around top and pull tree and roots out. or perhaps use FEL (front end loader) of tractor to push tree over.
backhoes for tractors, or excavators do good.
if you are not going to plow, till area, you could rent a stump grinder.
if you are wanting to drag a stump / log. getting the end nearest to pull vehicle up and off the ground some so it does not dig into the ground helps a lot. if you can get get end up on say a small pull behind car dolly or they make a kinda of a trailer. that you place near end of the log. and then use some rachet straps, to lift end of log up. and then hook up to hitch of truck or tractor and pull log to were ever.
   / Stump drager #11
as far as things breaking and whipping back at you and possibly killing you....
a heavy duty blanket placed over chain (the heavier the better) can help reduce amount of swing / whip chain has if it snaps.
if your chain has big enough holes in it. run a rope loosly within the holes through out the chain. and if chain brakes. the rope holes the chain from whipping.
if you have a good size tree nearby, you can add a chain around the other tree and attach a pulley. and use some cable to do things.
regardless of anything you use, chain, cable, rope. it all can and will break and snap and whip back at you at deadly force. been there done that with close calls. i try my best, to drive off straight, and right as the chain, cable, rope gets tight, i try to drive off at a sharp angle. purpose is if it does break and whip. hopefully i will be further off to the side vs directly in the path of the whipping chain, cable, rope.
also do not get a running start and "snap" the chain, cable, rope. high chance what ever you are using will break and whip back at you. just go slow and get things tight.
try to keep your chains, cable, rope. shorter. longer you use, more likely things will break. eerrrrr chain is only good as the weakest link. longer chain is, more likely there is a weaker link. goes for cable and rope as well.
   / Stump drager #13
not really sure what your after but I saw some stump spades on a search a few days ago, looked like there were for bob cat type loaders,
a short heavy triangle pointed bucket,
some had teeth on the edges of the buckets triangle and heavy flat point on the front that one could cut roots and pry with,
   / Stump drager #16
Get an Asian laborer:
Bruce
   / Stump drager #17
hard to explain, easy to do:
hook to the back side of the stump, run the chain over the top, over a levered post and onto the tractor. Kind of like a front foot judo throw.
I lifted out some 2000 lb stumps with a 1300 lb tractor that way. Roots were cut first.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
48x4 Mini Skid Trencher (A61307)
48x4 Mini Skid...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
