Stump bucket for small tractor
   / Stump bucket for small tractor #11
Stumps are amazing hard to remove, even with a mini ex.
   / Stump bucket for small tractor #12
Folks on YouTube make it look easy.
It's not easy on the tractor FIL and takes about 2 hours OR longer that you think it will.
It mostly depends on the type and size of the stump. I have a 40hp and will no longer try to remove any stump over 12/14" dia.
Wow! 12-14" seems big to me. I removed a good handful around 8-10" and even that was a serious PITA.
   / Stump bucket for small tractor #13
I've been contemplating buying one for my T293, for digging out bushel basket sized rocks. Figure that If the tractor really doesn't like it, I can rent a skid steer and use it on that.
I think digging out rocks close to the surface would be a HECK of a lot easier than stumps. Rocks don't have roots.
   / Stump bucket for small tractor #15
This is one I dug out with the stump bucket.
This one was a PITA even with a large trackloader. This was a brother in law project. I showed up sight unseen. He told me it was decent size but thought it was mostly rotted.
   / Stump bucket for small tractor #16
Yeah I am sure with a skid steer 12-14" wouldn't be as bad. But that is a lot for a compact tractor.
   / Stump bucket for small tractor #17
I have a Case TV620B. Weighs in at 16,800 so a 12"-14" only takes a couple minutes. On a tractor it's a lot of work and very hard on the FEL.
   / Stump bucket for small tractor #19
What about digging holes for planting trees?
Mine has been used to plant close to 100 trees between mine and my neighbors. It's a lot easier with 2 people. It's hard to see where you are digging. Especially if you don't have your seat safety switch disabled. Standing up it's doable
   / Stump bucket for small tractor #20
The only reason I miss mine is to dig small holes. It could even do a decent job at making shallow trenches.
Toro z turn (A56859)
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
LOT: (18) Scraper Bars for Sakai Pad Roller (A59076)
LOT: (18) Scraper...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
