Stuck up 3PH
/ Stuck up 3PH #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
My bro' inlaw in florida has the box blade on his kubota(grey L1500DT) <closest US model is an L175> stuck in the up position. The 3 point lever doesn't allow it to lower no matter which position its in. I asked him if someone changed the valve regulating the lowering speed, but he didn't think so. I seem to remember this happening to me years ago when I owned it, but can't remember how I fixed it. Anyone got any ideas ?? Thanks.......Tom (Since I'm in OH it's hard to go over for a quick look !!)
/ Stuck up 3PH #2
Could be that the lowering speed control has it locked in the up position, or if the lift arms were forced up higher than they are supposed to go, it could pull the hydraulic piston out of the cylinder inside the top cover. That's all I can think of unless someone dumped a dose of Levitra in your hydro oil. /forums/images/graemlins/blush.gif
/ Stuck up 3PH #4
If it stays that way more than four hours, your supposed to call a doctor.
/ Stuck up 3PH
Enough is enough !! <font color="red"> When the right moment.......becomes a TBN more seat time moment........ </font> ....but really......is something over centered or hanging up.........someone must have a 25 year old 'bota this has happened to ??
/ Stuck up 3PH #6
The flow control for down-motion of the 3 point hitch - knob under the seat - counterclockwise for faster drop - turned full clockwise the hitch stays up. I seem to remember that it has to turn several turns to start dropping if closed. Also some strange memory is saying that the load on the 3 pt needed to shake up and down to start dropping? (The actual pressure at the needle valve isn't very high so it needs a little help to get moving) Cheerful refund if info is bogus.
/ Stuck up 3PH #7
I don't know about this tractor, but if memory serves, the MMM lift and 3PH lift are tied together. If you set the MMM lift knob a certain way (not in the locked up position) if affects the function of the 3PH.
I may have it wrong, but it wouldn't hurt to check
/ Stuck up 3PH #8
most of the MMM and the 3ph are attached and If the mower is in the locked-up setting the 3ph won't go down. True Story
/ Stuck up 3PH #10
Yes, but the question is does it have an MMM control? The control could be what is keeping the 3PH up. This is even more likely if there is no MMM, because he wouldn't be familiar with the operation of the control and a little thing like that could have been changed and cause this big problem.
3PHs tend to have a problem going up when there is a problem, not going down.
/ Stuck up 3PH
The kubota only has one lever to the right of the seat.........this is a older machine. ( up , hold , down, float) Would it be possible backing up on a pile of gravel to over center something internally ?? You would think the hyd cylinder would be built so it has some type of stop or safeguard so this wouldn't happen.............I didn't ask him how it came to be stuck..........maybe there's a story here I'm not aware of ??.............. I had this tractor 10 years before I sold it to him & it went to Florida........I remember this happening once to me, but don't know what I did to remedy it........I know I didn't have to take anything apart..........But the rest is a blur...........Tom
/ Stuck up 3PH #12
I am new to the forum and came across your thread and had something simular happen to me so I thought I would share it.
I had my little mitisubishi 374 do that once and found the piston stuck.
I added lots of weight to the 3pt and it broke loose and has been working since.
The reason for the piston sticking was due to corrosion had set up due to lack of use.
Hope this helps.
/ Stuck up 3PH
The bro'inlaws been out of town & I haven't heard an update...........I hope its drifted down by now........Tom
90in. Work Bench (A65640)
90in. Work Bench...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
