Stuck on a hill
/ Stuck on a hill #1
SevenCorners
Charlottesville VA
Jinma 224 2004
I finally got her stuck today. I was cutting up firewood. I used the tractor to pull out 8' long pieces of oak. I made a mistake in backing up instead of using forward to pull the logs out. I did not realize that the ground was damp under the leaves. I started to back out, uphill, and instead of moving uphill the tractor slide downhill. At first it was only a couple of feet down hill and of course I tried to get it out by giving it more throttle. It only made matters worse. I am now about 7' down a very steep incline with the bucket braced against a tree holding back the tractor. My wimpy 1 ton come'along is worthless in this case. I am going to go down to TSC tomorrow and get a heavier duty come'along. Do you think 3tons is sufficient. I tried to back my F-250 4X4 down to it but was worried it too would get stuck. My neighbor down the road has a large JD 2 wheel drive. I will give him a ring tomorrow if my come'along idea doesn't work. They are calling for snow tomorrow so I hope I can get it out....
/ Stuck on a hill #2
</font><font color="blue" class="small">( with the bucket braced against a tree holding back the tractor. )</font>
Rather than take a chance at embarrassing yourself in front of the neighbor, remember you've got several forms of traction assist available to you. If you haven't already, engage the front wheels and and the diff lock. Then crab yourself back uphill in the lowest reverse gear available. Use minimal hand throttle - no foot throttle - using the FEL bucket as a pusher.
//greg//
/ Stuck on a hill
Greg,
At the risk of sounding really dumb, I don't think I have a diff lock. The hill is really steep and I am in a very bad spot where I can't go forward or back. I tried pushing with the bucket but did not get anywhere with it. There is a significant drop off that I need to get up , it is almost vertical for 2 ft. Once I can get the wheels to clear it I should have no problem getting the rest of it unstuck. I am concerned that it is really getting cold tonight and I will probably have trouble getting it started tomorrow due to cold it will be in the teens tomorrow morning. I have no electricity out there too far for extension cords, I do have a portable generator I might use with a couple of heat lamps.
/ Stuck on a hill
Also the ground might freeze tonight making it easier in the morning. The mud is really slick, clay and leaves. If I had traction I could get out.
/ Stuck on a hill #5
You know seven with the luck you've been having with your tractor breaking like it did, your one of the few I've known that if you didn't have bad luck you wouldnt have any luck at all. /forums/images/graemlins/frown.gif
/ Stuck on a hill
Well I have been relatively trouble-free recently so I guess I am due. At least nothing is broken.
/ Stuck on a hill #7
SHHH... it's not out yet!!! /forums/images/graemlins/wink.gif
Good Luck tomorrow ... Scozz
/ Stuck on a hill #8
The heck with being embarrased in front of the neighbor, if he is a good heighbor he will be happy to be of help. Jeezz, I have managed to get a 4 wheel drive cab tractor with 130Hp stuck to where it took a bull dozer to get her out, yeah, I took a little ribbing. All in good jest, but she is out, no damage, and free.
Sometimes we all need a little assistance.........it makes you now less a man........only human. Plus I am sure at some time in the future you can repay the favor or at least pass it on.
/ Stuck on a hill #9
</font><font color="blue" class="small">( I don't think I have a diff lock. )</font>
I'd be surprised if you don't. It's item 25 in this view. Another trick is skid steering, but you should be in 2wd and without diff lock to get the most control out of that technique.
//greg//
/ Stuck on a hill
No diff lock. I looked at diagram and I have nothing similar on my tractor, on the right side I only have 3 levers, one for 3pt up down, one for engage PTO and one for [I think] future use like BH.
Anyway I called a local tow company and they winched me out, I would not have gotten out using my truck or come along. I was too far down for those to be much good. nothing hurt except my wallet $100 less. I learned a lesson never about getting too close to an edge.
/ Stuck on a hill #11
thank the good Lord they got ya out almost pain free. You might look into water weight in the tires, not sure how to do it but I know ya use salts to keep it from freezing and ya might look into some serious chains for the tires. I once had a plow truck stuck in a side culvert where water was running under ice. couldnt get it out, got frozen in and waited for a thaw to get me out with a bulldozer.
/ Stuck on a hill #12
</font><font color="blue" class="small">( No diff lock. )</font>
I've never heard of one without a locking differential. Where did you buy that 224/
//greg//
/ Stuck on a hill #13
Seven,
Look at your owners manual first. It should show the levers. It is located on the right side along your seat. Mine says engaged/disengaged on the handle knob and which direction to move to do so. If you follow the lever to where it enters the trans it will be a cam(eccentric) that pushes in on a rod which internally locks the two wheels. This is a diff lock.
/ Stuck on a hill #14
The "future use" lever is the Diff lock, feels like it does nothing, but pushing it down will lock the rear wheels together, makes it hard to steer so be careful with it.
/ Stuck on a hill #15
the dif loc is the lever just to the right as said, it is LONG and the lever moves very freely (or should) and then it meets a springy type resistance, DON'T FORCE IT, just hold it with a slight amount of pressure forward and there is a plate that has holes in it the plate has a matching plate with PINS in it the pins have to align to engauge, holding the lever in will lock it inplace when they align and ONLY when they align. also you need to HOLD it in once engauged or else when you turn it will come out by spring pressure back to off or disengauge spot.
Mark M
/ Stuck on a hill
Harry,
I looked over my manual, and it is the same diagram as the one Greg linked too, only it is not my configuration, sigh..... So manual is no help. I took a picture for all to see.
/ Stuck on a hill
Man do I feel stupid,,, I have had this tractor since Aug and I still don't know how to properly operate it. All please excuse my ignorance. I really wish I had bought my tractor from a local dealer so he could have given me the low down. I don't know how I would have made it without this forum.
Thanks Guys!!!!
/ Stuck on a hill #20
<font color="red">
Man do I feel stupid,,, I have had this tractor since Aug and I still don't know how to properly operate it. All please excuse my ignorance. </font>
Don't beat yourself up, I learn something new almost every time I use my tractors! Then again, I sell candy to kids so that doesn't take much brainpower! These are fun toys that make life much easier for the operators, but it takes a lot of time to learn all the little tricks on how to operate them.
(INOP) 2009 FORD F-250 XLT SUPER DUTY CREW CAB TRU (A62130)
(INOP) 2009 FORD...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
LOT LOCATIONS (A59910)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
UNUSED WOLVERINE DB-15-84W 84" HYD PUSHER BLADE (A62131)
UNUSED WOLVERINE...
