Stuck Inside
   / Stuck Inside #81
The coldest that I've seen here (kansas city area) was -26 back in the 80's one time. That cold air would freeze in the carburetor of my Dodge pickup (slant 6). It was at night, getting off work, that it would start fine..........but then die right after I stepped on the gas. As soon as the weather warmed up, it ran fine again. I had to walk to a service station and was so cold that I was shaking for quite awhile.
I'll bet the shelters are packed with people today, since it is only zero right now...........fortunately the wind is nearly calm.
Warm Cheers To All,
Mike
It has warmed up here now with the sun shining, We are up to 10 degrees. Whooo Hooo.
   / Stuck Inside #82
Currently -10 F. Last night where I'm at in Minnesota, it was colder than anywhere in Canada or the arctic circle. South of me in Leader MN, they hit -40 F.
   / Stuck Inside #83
Dave......hope your BX ride is fun. Me, ......think I'll wait a couple days. There wasn't all that much snow to deal with. Maybe just get the shovel out for the patios....cabin fever is setting in though.:)
Cheers,
Mike
Didn't take long for my drive and the neighbor. Was good to see the sun. Drive already starting to melt.
   / Stuck Inside #84
Am I reading this right that the inside humidity is at 18%?
   / Stuck Inside #86
I hadn't thought about the humidity until I saw this. So my gauge shows 20% and 73 degree temperature on the fireplace mantle (fireplace not being used). We have a humidifier, but it hasn't been used since last winter; may have to plug it in and put some water in it.
   / Stuck Inside #87
Ideal is at least 40% but when I have a fire going it does get into the 20s. I put 2 kettles of water on the wood burner.
   / Stuck Inside #88
Man that's cold, 13° right now with a little sun shining through. I'm not sure what the humidity is in the house probably low.
   / Stuck Inside
It's zero here right now... That's 0 degrees. Watched two football games today and shoveled some snow....not enough to fire up the Kubota...and the rest should melt in a couple days.
   / Stuck Inside #90
I went outside today to work on stuff.
-20 F plus wind chill is no joke.
Welcome to Minnesota.
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
