Stuck in the mud
   / Stuck in the mud #11
Stuck? Ha, you weren't stuck, just slowed down a little.
Ways out with a come along, chain to a tree. You can use the bucket curl to pull youself forward 2' at a time. Good H-bar mud chains help. Digging out and placing boards, sticks and stuff in the rut are good too. Best way out is not to go in, but we all do one time or another.
Funny story -- I was comming out from rototilling food plots one spring. The ground was tore up in the murky areas on the way in and with some sprinkles and run off, it became a death trap for me on the way out. I sat there stuck up to the axles, thinking. As I had stopped spinning the tires and started thinking right away I got out. How? I lowered the tiller, engaged the PTO clutch, locked the differential and tilled my way out! The tiller acted like a propeller and gave me the push I needed. Good thing it is not a reverse till unit!
jb
   / Stuck in the mud #12
John: That's a great idea; I wish I had thought of that! I may have to try your method this spring. Jay
   / Stuck in the mud #13
Pine or spruce tree branches under the wheels also work well.
Ain't being stuck GRAND!! /forums/images/graemlins/cool.gif
Egon /forums/images/graemlins/grin.gif
   / Stuck in the mud #14
Two words: HDAP tires. They float better and will not sink up in mud. You could use them all the time, or switch them out during certain months. They should not be too expensive. Industrials are made for load bearing and for traction when pushing or pulling. They do not flex enough or have aggressive enough tread to counter muddy conditions. Even though your little tractor is stout it is heavy for its size and once sinking, it will drop like a stone. To me, the key is to stay on top of the soft areas. My older 595 which I no longer have, would float over mud with it's HDAP's.
John M
   / Stuck in the mud #15
One of the things I learned from my old man and I learned it by watching him do it wrong. When you realize you are stuck STOP. Don't keep trying as that only digs you deeper. Figure out what you are going to do and proceed. His method was to floor the accelerator. Very good for working off frustration but...
I have been stuck in my PU twice. Both times on flat ground with the rear end only a few feet from the road. Both times just turning around (J turn). 1st time I pulled into what looked like solid sod and promptly sunk to the axles on both ends. That took a lot of jacking and packing brush. Fortunately there was an old hay wagon that I was able to take boards off of to block the jack.
Second time was even more frustrating. Again flat, level ground early in spring. Pulled in the back out and turn around. and just sat there. Wheels turned to instand slicks, didn't sink but slightly but there I sat. All I had was a welder's helmut to pack gravel in. That was a fun mess cleaning out afterward.
Harry K
   / Stuck in the mud
Thanks again for all of the suggestions. I did spin the tires a few times, probably should have stopped after the second round of trying to rock the tractor out. Probably also going to invest in some chain or a come-along for when ( not if) this should happen again. Figured lots of folks had probably had done this, but the grass looked so innocent. now up to about 2 hours of total tractor driving time (told you I was a newbie- used to use a push mower before we bought this property). Thanks folks!!!!!
   / Stuck in the mud #17
I like the "stop" advice....whatever it is that's stuck, tractor, truck, dozer, etc. stopping and letting your brain look for a solution is a great approach rather than making the problem worse. I stuck my small dozer last weekend. Got off of it and surveyed what seemed to be a hopeless situation. Then decided to use the blade to lift the buried tracks so that I could put some logs under it and then drove it out of the mess. /forums/images/graemlins/smile.gif
   / Stuck in the mud #18
Nice having a backhoe on the backside too as you can push yourself out with it, or crab sideways.
I was down on the "beach" (lake drawn down to "winter pool" levels and this is the exposed muck that is usually under water during summer months) and stuck to rear axel.
Used hoe to lift tires out, put stabs down to keep me up, then just crabbed my way over to better ground.
(had TVA's permission to remove some of the accumulated silt on the 'beach')
   / Stuck in the mud #19
I stuck my 5500 Mahindra 2 weeks ago. I just started sinking in some bottom land clay. I stopped and got off to call my uncle with a dozer. He wasn't home so I went back. The tractor had sunk below the floorboards, I had to step up a foot to get off the tractor. The R1's were completely clogged so there not always the answer either. The bucket couldn't curl me out as it just sank in the muck. I put a crosstie under it but it sank it about 2 feet too. I ended up having to have a wrecker get me out.
   / Stuck in the mud #20
Harry,
You hit the nail on the head. "Know when to fold'em". I have lived on a long hilly drive for 20 years. When she is covered in snow, you have one chance to do it right. Otherwise you make it up halfway and slide down inthe ditch!
If your spining it's time to use that thing called the off switch/fuel kill. Get off and see what needs done. So often if you just stop and get a bucket of gravel/use your loader/or wait until tomarrow, your axels won't become so familer with ground level!
I once was getting firewood from the back 40 in my Chevy pickup. I tried to cross a small dry creek...at good speed. I ended up with front and back bumpers sitting on the banks. Wheels a hanging. It took WEEKS of jacking, shoving stuff under the wheels and come-alonging to get it back out.
Since then I learned.."honey..can I get I ride to work with you?"
Kubota BX25D (A53317)
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X6JD476305 (A57453)
2018 Peterbilt 389...
Tractor Tires and Rims (A56860)
Tractor Tires and...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
3410 (A47477)
3410 (A47477)
