stuck clutch
/ stuck clutch #1
gary65cars
the clutch on both my 102 and 108 are stuck. You can't stop them without the kill switch.Is it internal or can i do something without tearing it apart?
/ stuck clutch #2
Not sure what a 102 or 108 is.
Assuming some sort of tractor, one thing to try would be mashing the brakes hard and trying to break the plates free.
On my dozer I used the brakes to break the steering clutches free after sitting for some time. Forward and back, forward and back.
Joel
/ stuck clutch #3
G'day i have got them unstuck by driving around with my foot on the clutch and on and off the throttle, hope this works for you otherwise it's time to open her up:)
Jon
/ stuck clutch #4
If you have a plow or box blade the would help put more stress on the clutch and maybe free it up. Just remember to keep the clutch pedal depressed.
/ stuck clutch #5
Put it in the highest gear, block the clutch peddle down or have someone sit and hold it down and rock it back and forth with the rear tire. Not running of course.
/ stuck clutch #6
This is a commonly discussed issue. Search under "stuck clutch" and you'll get all kinds of good advice. Based on what I've read you should be able to unstick your clutch without going internally.
Good luck, and be sure to post what works for you.
/ stuck clutch #7
had it happen one time: had to break the tractor in two in order to get it unstuck: hope you have better luck.
heehaw
/ stuck clutch #8
Any chance it sat for while? Just a guess. Another suggestion that's worked for me:
Attach something to the PTO takes some energy to get started (a brushhog, chipper, etc). Then engage the PTO while holding down the clutch. If it doesn't break free then quickly accelerate the throttle while still holding down the clutch.
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2024 DYNAPAC CA30D PADFOOT ROLLER (A62129)
2024 DYNAPAC CA30D...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
KJ 10' FORK EXTENSIONS (A62131)
KJ 10' FORK...
